| 0000074 | FreeCAD | Bug | public | 2010-03-05 13:27 | 2010-03-05 15:25 |
| Reporter | wmayer | Assigned To | yorik | ||
| Target Version | 0.10 | Fixed in Version | 0.10 | ||
| Summary | 0000074: Offset doesn't work as expected | ||||
| Description | Following the tutorial at https://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Draft_tutorial I run already into an issue when trying to offset the initial rectangle. After starting the Offset command and moving the cursor then this happens: * when shrinking in vertical direction the rectangle grows in horizontal direction * when growing in vertical direction it shrinks in horizontal direction The same effect is occurring when moving the cursor in horizontal direction where it grows/shrinks in vertical direction. | ||||
| 2010-03-05 13:27 | wmayer | New Issue | |
| 2010-03-05 13:27 | wmayer | Status | new => assigned |
| 2010-03-05 13:27 | wmayer | Assigned To | => yorik |
| 2010-03-05 13:47 | unauthenticated | Note Added: 0000180 | |
| 2010-03-05 15:25 | yorik | Note Added: 0000181 | |
| 2010-03-05 15:25 | yorik | Status | assigned => closed |
| 2010-03-05 15:25 | yorik | Resolution | open => fixed |
| 2010-03-05 15:25 | yorik | Fixed in Version | => 0.10 |
