0000741DraftBugpublic2012-08-11 19:30
Reportermore10 Assigned Toyorik
Product Version0.12
Target Version0.13Fixed in Version0.13
Summary0000741: imported dxf not rendered correctly
DescriptionA dxf file from rexroth is not rendered correctly
Additional InformationAttached dxf file and images from freecad and draftsight. Version is 0.13, revision 1091.
more10
2012-06-07 18:55
reporter   ~0002149
If I convert the dxf to svg using gcad3d-1.80, the svg is correctly rendered
2012-06-07 18:59
shoogen
2012-06-07 19:10
developer   ~0002151
i can't repoduce it with 0.12 and 0.13.1074 on win7. What is your setting for the internal draft precision?
2012-06-08 17:02
test.FCStd (340,466 bytes)
yorik
2012-06-08 17:04
administrator   ~0002159
For me all seems normal too (see attached test.FcStd)
Can you attach a screenshot that shows the tree view too? I'm curious about what dxf import settings you used...
yorik
2012-08-11 19:30
administrator   ~0002319
unable to reproduce and not enough feedback...
2012-06-07 18:12 more10 New Issue
2012-06-07 18:12 more10 File Added: Rexroth-3 842 990 350_200MM.zip
2012-06-07 18:55 more10 Note Added: 0002149
2012-06-07 18:59 more10 File Added: Rexroth-3 842 990 350_200MM.svg
2012-06-07 19:10 shoogen Note Added: 0002151
2012-06-08 17:02 yorik File Added: test.FCStd
2012-06-08 17:04 yorik Note Added: 0002159
2012-06-08 17:04 yorik Status new => feedback
2012-06-12 16:52 yorik Status feedback => assigned
2012-06-12 16:52 yorik Assigned To => yorik
2012-06-12 16:53 yorik Project FreeCAD => Draft
2012-06-12 16:54 yorik Target Version => 0.13
2012-08-11 19:30 yorik Note Added: 0002319
2012-08-11 19:30 yorik Status assigned => closed
2012-08-11 19:30 yorik Resolution open => unable to reproduce
2012-08-11 19:30 yorik Fixed in Version => 0.13
