| 0000742 | Draft | Bug | public | 2012-06-07 23:52 | 2012-06-13 20:37 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Platform | 32 bit | OS | Kubuntu | OS Version | 12.04 |
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000742: popup window "workbench failure" - "float divide by zero" | ||||
| Description | When switching to Draft or Arch WB a window pops up titled "workbench failure" with a message "float division by zero". It only happens if you have a document, either a new empty doc, or one containing a project. It does not happen if you first start FreeCAD then switch between workbenches before you have created a new document or opened an existing one. This problem only started for me, this morning my time, a few hours before this post. On Kubuntu 12.04 32bit Version: 0.13.1097 (Git) Branch: master Hash: 04d21035669c99e77e5b2b5c4a01d678e0181456 I have since upgraded from git /master and compiled and the problem is still there in the new version of FreeCAD as below: - Version: 0.13.1104 (Git) Branch: master Hash: e7644fd3b32e487b915249ac86949495e9401ae6 | ||||
| Steps To Reproduce | start FreeCAD either open existing project or create a new blank project then switch to either Arch or Draft WB then the error window will pop up. | ||||
Hm I can't reproduce this, no matter what I do... |
Do you still have this problem Jim? I can't reproduce it... |
I have bug: 'NoneType' object has no attribute 'set' when switching to draft module. git 1129 win7 |
Okay I think I got it... See if it works now? |
ok, it works now. |
Ok this looks fixed so I close it. Don't hesitate to reopen if needed... |
| 2012-06-07 23:52 | jmaustpc | New Issue | |
| 2012-06-08 05:28 | wmayer | Status | new => assigned |
| 2012-06-08 05:28 | wmayer | Assigned To | => yorik |
| 2012-06-08 13:21 | yorik | Note Added: 0002157 | |
| 2012-06-11 15:40 | yorik | Note Added: 0002181 | |
| 2012-06-11 15:41 | yorik | Status | assigned => feedback |
| 2012-06-11 18:08 | pperisin | Note Added: 0002183 | |
| 2012-06-11 18:18 | yorik | Note Added: 0002184 | |
| 2012-06-11 19:19 | pperisin | Note Added: 0002185 | |
| 2012-06-12 16:53 | yorik | Project | FreeCAD => Draft |
| 2012-06-12 16:54 | yorik | Target Version | => 0.13 |
| 2012-06-13 20:37 | yorik | Note Added: 0002199 | |
| 2012-06-13 20:37 | yorik | Status | feedback => closed |
| 2012-06-13 20:37 | yorik | Resolution | open => fixed |
| 2012-06-13 20:37 | yorik | Fixed in Version | => 0.13 |
