| 0000746 | PartDesign | Bug | public | 2012-06-11 09:30 | 2012-12-04 11:14 |
| Platform | 32 bit | OS | Kubuntu | OS Version | 12.04 |
| Summary | 0000746: Groove tool in PartDesign WB can't be moved nor can its sketch | ||||
| Description | Groove tool in PartDesign WB once a groove has been made it can't be moved nor rotated either by adjusting its own parameters nor the parameters of its sketch Full version data Version: 0.13.1124 (Git) Branch: master Hash: 6c16628f4e0ed88ca12c05877c43602d71219134 | ||||
| Steps To Reproduce | do a sketch, pad, do a sketch on the side of the Pad, groove a few degrees, then try and adjust any axis or position parameters. The groove objects parameters are, I believe, deliberately set to read only. However the sketches parameters change but immediately revert once you click away from the parameter. | ||||
| child of | 0000745 | closed | Groove often fails or does unexpected things |
This same problem exists in the same manner with PartDesign Revolve |
Same problem with pocket and pad. Maybe this is intended behaviour because with the upcoming Body Feature there should only be a single placement, namely that of the Body, which all other features inherit from? |
I think this issue is fixed. But I realized a different problem: if the groove axis intersect its sketch the application hangs. |
Proposed fix see github jrheinlaender/PartDesign-0.14 http://github.com/jrheinlaender/FreeCAD/tree/jrheinlaender/PartDesign-0.14 |
| 2012-06-11 09:30 | jmaustpc | New Issue | |
| 2012-06-11 10:05 | jmaustpc | Note Added: 0002175 | |
| 2012-06-11 10:39 | wmayer | Relationship added | child of 0000745 |
| 2012-06-11 14:02 | jrheinlaender | Note Added: 0002178 | |
| 2012-07-01 12:53 | yorik | Project | FreeCAD => PartDesign |
| 2012-11-23 16:52 | wmayer | Note Added: 0002581 | |
| 2012-11-30 12:01 | jrheinlaender | Note Added: 0002604 | |
| 2012-12-04 11:14 | wmayer | Status | new => closed |
| 2012-12-04 11:14 | wmayer | Resolution | open => fixed |
| 2012-12-04 11:14 | wmayer | Fixed in Version | => 0.13 |
