| 0000747 | PartDesign | Bug | public | 2012-06-11 09:41 | 2012-11-01 09:11 |
| Platform | 32bit | OS | Kubuntu | OS Version | 12.04 |
| Summary | 0000747: Groove tool in PartDesign WB reverts to producing a solid revolve | ||||
| Description | Groove tool in PartDesign WB reverts to producing a solid revolve, rather than removing material with a groove, on anything other than an initial Pad Full version data Version: 0.13.1124 (Git) Branch: master Hash: 6c16628f4e0ed88ca12c05877c43602d71219134 | ||||
| Steps To Reproduce | create a sketch, pad, select a side face of Pad, create another sketch, groove from the second sketch, create another sketch, try to groove, groove produces a solid revolve, not a groove Or an alternative method go to Part WB click on Box create a sketch try to groove you get a solid revolve | ||||
| Additional Information | Here's a test file as an example | ||||
| child of | 0000745 | closed | Groove often fails or does unexpected things |
2012-06-11 09:41
Quote: - Or an alternative method go to Part WB click on Box create a sketch try to groove you get a solid revolve Actually on further testing, the above is not correct, it does work on Part box, just only the first time, that is it will work on another box created then moved elsewhere, the problem is when you try to Groove on the solid produced from a previous groove . |
2012-06-11 09:57
The groove feature was not checking whether the sketch has a support. Therefore the cutout of the groove fails when the sketch is not placed on the face of some solid. I pushed an updated FeatureGroove.cpp to https://github.com/jrheinlaender/FreeCAD branch jrheinlaender/PartDesign Or should I post a diff here instead? |
| 2012-06-11 09:41 | jmaustpc | New Issue | |
| 2012-06-11 09:41 | jmaustpc | File Added: testofgroove1_groovein_pad.FCStd | |
| 2012-06-11 09:57 | jmaustpc | Note Added: 0002174 | |
| 2012-06-11 09:57 | jmaustpc | File Added: test_of_groove2_groove_in_Part_box.FCStd | |
| 2012-06-11 10:40 | wmayer | Relationship added | child of 0000745 |
| 2012-06-11 12:37 | jrheinlaender | Note Added: 0002176 | |
| 2012-07-01 12:53 | yorik | Project | FreeCAD => PartDesign |
| 2012-11-01 09:11 | logari81 | Resolution | open => fixed |
| 2012-11-01 09:11 | logari81 | Status | new => closed |
| 2012-11-01 09:11 | logari81 | Fixed in Version | => 0.13 |
