| 0000748 | PartDesign | Bug | public | 2012-06-11 11:29 | 2012-11-01 09:22 |
| Platform | 32 bit | OS | Kubuntu | OS Version | 12.04 |
| Summary | 0000748: reverse revolve from a sketch mapped to face of Part box and a solid from PartDesign Groove inconsistency | ||||
| Description | reverse revolve from a sketch mapped to a face of a Part Box produces a box with a revolved knob hanging out the side. whereas reverse revolve from a sketch mapped to a face of a PartDesign solid product of the groove tool, gives you just the revolve. The box with the groove in it disappears. That is, the original box with a groove in it is set to view mode "hidden" and a copy of this box with groove in it is not attached to the reverse revolve which should have been hanging out the side of it. full version data Version: 0.13.1124 (Git) Branch: master Hash: 6c16628f4e0ed88ca12c05877c43602d71219134 | ||||
| Steps To Reproduce | create a Part Box select a side face make a sketch revolve tool on the sketch to for example 60 degrees and set reversed produces a box with a revolved knob hanging out the side. However create a Part Box select a side face make a sketch groove tool on the sketch to for example 60 degrees correctly Produces a box with a grooved slot in it select the same side face again (but now it is a face of the groove solid not the original box) make a new sketch mapped to that face revolve tool on this new second sketch to, for example, 60 degrees and set reversed You get a revolve shape but the "box with a groove in it" is missing | ||||
| Additional Information | here is two example files | ||||
| child of | 0000745 | closed | Groove often fails or does unexpected things |
2012-06-11 11:29
2012-06-11 11:30
The groove feature needs to extract the solid from the result of the cut operation in case a compound was created. I pushed an updated FeatureGroove.cpp to https://github.com/jrheinlaender/FreeCAD branch jrheinlaender/PartDesign |
| 2012-06-11 11:29 | jmaustpc | New Issue | |
| 2012-06-11 11:29 | jmaustpc | File Added: test_of_groove4_sketch_revolve_reverse_mapped_to_a_groove.FCStd | |
| 2012-06-11 11:30 | jmaustpc | File Added: test_of_groove5_sketch_revolve_reverse_mapped_to_a_box.FCStd | |
| 2012-06-11 12:48 | wmayer | Relationship added | child of 0000745 |
| 2012-06-11 13:56 | jrheinlaender | Note Added: 0002177 | |
| 2012-07-01 12:53 | yorik | Project | FreeCAD => PartDesign |
| 2012-11-01 09:22 | logari81 | Status | new => closed |
| 2012-11-01 09:22 | logari81 | Resolution | open => fixed |
| 2012-11-01 09:22 | logari81 | Fixed in Version | => 0.13 |
