0000751FreeCADBugpublic2012-06-13 18:05
Reporteresteewhy Assigned Toyorik
PrioritynormalSeveritytrivialReproducibilityalways
Product Version0.12
Fixed in Version0.13
Summary0000751: Typo in importSVG causes incorrect importing of Bezier curves
DescriptionSVG drawing, exported from InkScape is heavily distorted after being imported as geometry into FreeCAD.
This is seemingly caused by a typo in [FreeCAD0.12\Mod\Draft\importSVG.py], lines 562 and 563 are now:
  pole1 = Vector(point[0],point[1],0)
  pole2 = Vector(point[2],point[3],0)
But they should read:
  pole1 = Vector(point[0],-point[1],0)
  pole2 = Vector(point[2],-point[3],0)
(A test case is attached.)
00044-cc.svg (Attachment missing)
yorik
2012-06-13 18:05
administrator   ~0002198
Hi,
Thanks for reporting and even bigger thanks for bringing a solution too!
The problem you are reporting has already been fixed in development version, the whole bezier curves handling has been totally rewritten since then...
As far as I can see, your example file now gives exact same results in inkscape and freecad.
Those changes will be available in next release of FreeCAD (but you can also grab a development version, see instructions on http://free-cad.sf.net )
If this is still a problem, don't hesitate to reopen this issue.
2012-06-13 11:11 esteewhy New Issue
2012-06-13 11:11 esteewhy File Added: 00044-cc.svg
2012-06-13 12:45 wmayer Status new => assigned
2012-06-13 12:45 wmayer Assigned To => yorik
2012-06-13 18:05 yorik Note Added: 0002198
2012-06-13 18:05 yorik Status assigned => closed
2012-06-13 18:05 yorik Resolution open => no change required
2012-06-13 18:05 yorik Fixed in Version => 0.13
