| 0000759 | FreeCAD | Bug | public | 2012-06-21 16:54 | 2012-06-22 20:09 |
| Reporter | shoogen | Assigned To | yorik | ||
| Summary | 0000759: importSVG produces unorientable shapes by creating Faces from open Wires. | ||||
| Description | The SVG standard allows open paths to be filled. Which means the path will be closed but the contour is of the closing line is not drawn. The previous behavior produces broken shpaes. | ||||
| Additional Information | The suggested behavior is to neglect the fill style in case of an open path. The following changes since commit 2828a91b7bded9757a96a93905b815ccdc5a1a50: Fix a couple of dfsg issues, make git the default vcs (2012-06-21 12:25:53 +0200) are available in the git repository at: git://github.com/5263/FreeCAD.git svgimport for you to fetch changes up to 7147f3dd55ae1661d6fee431cafccd4e7e536f8a: importSVG: create Face only if path is closed (2012-06-21 15:11:16 +0200) ---------------------------------------------------------------- shoogen (2): importSVG: fixes in preserveAspectRatio and sweepflag handling importSVG: create Face only if path is closed src/Mod/Draft/importSVG.py | 22 ++++++++++++---------- 1 file changed, 12 insertions(+), 10 deletions(-) | ||||
| 2012-06-21 16:54 | shoogen | New Issue | |
| 2012-06-22 00:56 | yorik | Status | new => assigned |
| 2012-06-22 00:56 | yorik | Assigned To | => yorik |
| 2012-06-22 00:56 | yorik | Note Added: 0002232 | |
| 2012-06-22 20:09 | yorik | Note Added: 0002233 | |
| 2012-06-22 20:09 | yorik | Status | assigned => closed |
| 2012-06-22 20:09 | yorik | Resolution | open => fixed |
| 2012-06-22 20:09 | yorik | Fixed in Version | => 0.13 |
