| 0000769 | Draft | Bug | public | 2012-07-01 11:34 | 2012-12-19 13:52 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Platform | 64 bit | OS | kubuntu | OS Version | 12.04 |
| Summary | 0000769: Draft Dimension crashes FreeCAD after parameter change | ||||
| Description | Changing the text of Draft Dimension from 2d to 3d and back again, crashes FreeCAD. Also once crashed on changing the z position value of the text. forum link https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=2759&p=21085#p21085 | ||||
| Steps To Reproduce | In the file attached to this ticket, if I adjust back and forward between 2d and 3d text in dimension002 and then push the mouse over the model then it crashes, although sometimes I have to do so a few times before the crash happens. | ||||
| Additional Information | Platform: Ubuntu 12.04 LTS (64-bit) Version: 0.13.1213 (Git) Branch: master Hash: 9a269907aaf0f274ddea66c576b9a429258bdf1e Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
2012-07-01 11:34
Be careful with setValues(): The line self.line.numVertices.setValues([3,3]) makes a list of two ints with the values 3 and 3. So far, so good. The line self.line.numVertices.setValues([4]) only updates the first value of the list but it does NOT decrease the number of elements to 1, it's still 2. So, we have the list with the values 4 and 3. Solution: self.line.numVertices.setValue(4) or self.line.numVertices.setValues([4]) self.line.numVertices.setNum(1) |
Thanks for the hint Werner! I think that was the main problem indeed, I committed the change, it seems more stable now, and doesn't crash the example file anymore. I'll keep this open until I check all the related issues... |
I think we can consider this fixed... |
| 2012-07-01 11:34 | jmaustpc | New Issue | |
| 2012-07-01 11:34 | jmaustpc | File Added: test_crash_with_dimensions.FCStd | |
| 2012-07-01 12:45 | yorik | Status | new => assigned |
| 2012-07-01 12:45 | yorik | Assigned To | => yorik |
| 2012-07-01 12:48 | yorik | Project | FreeCAD => Draft |
| 2012-07-02 09:49 | wmayer | Note Added: 0002255 | |
| 2012-07-02 10:57 | yorik | Note Added: 0002257 | |
| 2012-12-19 13:52 | yorik | Note Added: 0002668 | |
| 2012-12-19 13:52 | yorik | Status | assigned => closed |
| 2012-12-19 13:52 | yorik | Resolution | open => fixed |
| 2012-12-19 13:52 | yorik | Fixed in Version | => 0.13 |
