| 0000774 | FreeCAD | Bug | public | 2012-07-03 11:14 | 2012-07-03 14:28 |
| Platform | 64 bit | OS | kubuntu | OS Version | 12.04 |
| Summary | 0000774: merge project with these files instantly crashes FreeCAD | ||||
| Description | FreeCAD open this house file merge project select the lounge file | ||||
| Steps To Reproduce | open this house file merge project select the lounge file FreeCAD crashes | ||||
| Additional Information | Platform: Ubuntu 12.04 LTS (64-bit) Version: 0.13.1220 (Git) Branch: master Hash: de1543b5fef425af8c3292823c9f0d78f33a613a Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
2012-07-03 11:14
2012-07-03 11:15
link to the forum topic http://forum.freecadweb.org/viewtopic.php?f=8&t=2636&p=21158#p21158 |
2012-07-03 11:20
it crashes with merge project with either lounge file lounge has a boolean fuse of three simple copies (the fuse of the parametric components from which these simple copies were made had failed, hence I made simple copies and tried to fuse them, which worked but had on original creation showed an error exclamation mark over the fuse icon in the tree view. after closing and reopening the file it didn't report any errors) lounge2 I deleted that fuse in case it was causing the problem. |
git show feeaac9ecbde8f841c420992a8bf2d863ecf20da |
| 2012-07-03 11:14 | jmaustpc | New Issue | |
| 2012-07-03 11:14 | jmaustpc | File Added: the_VS_full_model_blocker_with_3d_drawings_wall_displaying_experiments.FCStd | |
| 2012-07-03 11:15 | jmaustpc | File Added: lounge2.FCStd | |
| 2012-07-03 11:15 | jmaustpc | Note Added: 0002267 | |
| 2012-07-03 11:20 | jmaustpc | File Added: lounge.FCStd | |
| 2012-07-03 11:26 | jmaustpc | Note Added: 0002268 | |
| 2012-07-03 14:28 | wmayer | Note Added: 0002269 | |
| 2012-07-03 14:28 | wmayer | Status | new => closed |
| 2012-07-03 14:28 | wmayer | Resolution | open => fixed |
| 2012-07-03 14:28 | wmayer | Fixed in Version | => 0.13 |
