| 0000789 | FreeCAD | Bug | public | 2012-07-09 11:28 | 2012-07-11 13:37 |
| Reporter | sliptonic | Assigned To | |||
| Summary | 0000789: Sketcher active in one document blocks closing another. | ||||
| Description | If you have two or more project documents open at the same time and open the sketcher in one of them, you can't switch to another document and close it. Doing so gives the error that the document is in editing mode. Presumeably, this means there are other things that can't be done like have two or more documents both in active editing mode at the same time. I haven't tested this. Naive expectation is that each open document behaves independently and that the left task panel corresponds to whichever document window has the focus. | ||||
> and that the left task panel corresponds to whichever document window has the focus. But this doesn't make sense to me and contradicts to this bug report. One reason for showing this message is to remember the user that a document is still in edit mode. But it's true that this should only be shown when trying to close the document which the task dialog was opened for. |
git show 484c801 |
| 2012-07-09 11:28 | sliptonic | New Issue | |
| 2012-07-11 13:33 | wmayer | Note Added: 0002287 | |
| 2012-07-11 13:37 | wmayer | Note Added: 0002288 | |
| 2012-07-11 13:37 | wmayer | Status | new => closed |
| 2012-07-11 13:37 | wmayer | Resolution | open => fixed |
| 2012-07-11 13:37 | wmayer | Fixed in Version | => 0.13 |
