| 0000802 | FreeCAD | Bug | public | 2012-07-21 11:04 | 2012-08-01 19:51 |
| Summary | 0000802: Draft scale - some problems and some suggestions | ||||
| Description | Hi, When I use Draft scale on a body that has one color per face (body with multiple colors), during "scale action", when scale values are choosen in the interface using mouse, I still see all the faces colors. But when I click final mouse click, that creates scaled object - it is single colored. Worst part is, After object is created this way, I do not have ability to color it any more. Also, it might be worth considering how does scale work in Sketchup: http://www.youtube.com/watch?v=I_xqUsZnzJA This is IMO much more user frendly. Regards Petar | ||||
Okay I can correct the color problem, but as for the sketchup scale, that means creating a complete new tool, and should be the matter of a specific feature request. There is some discussion about a scale feature on the forum too. |
OK, so here is the thing - I just found out that draft clone does the same thing and allows me to scale. Really nice. So I do not really need sketchup-based scale. I could work with clone. So what you could do is simply modify single color per face issue in this two tools (scale and clone) and close this request. Also, I can not find the thread where this is discussed, so can you please post link to it here? Regards Petar |
This makes me think I could make the scale tool produce a Draft clone. Would be handy, and the original shape would be kept instead of lost... Okay I'll do that and fix the color thing. |
Fixed in 6251510 |
Hi Yorik. Just a small note - this is not totally fixed - using draft clone still does not copy colors. However, draft scale works properly, and this is fixed in it. Regards, Petar |
Fixed again in 88ea348 |
| 2012-07-21 11:04 | pperisin | New Issue | |
| 2012-07-21 20:17 | yorik | Note Added: 0002296 | |
| 2012-07-21 20:17 | yorik | Status | new => assigned |
| 2012-07-21 20:17 | yorik | Assigned To | => yorik |
| 2012-07-22 12:34 | pperisin | Note Added: 0002298 | |
| 2012-07-22 14:02 | yorik | Note Added: 0002299 | |
| 2012-07-22 21:00 | yorik | Note Added: 0002301 | |
| 2012-07-22 21:00 | yorik | Status | assigned => closed |
| 2012-07-22 21:00 | yorik | Resolution | open => fixed |
| 2012-07-22 21:00 | yorik | Fixed in Version | => 0.13 |
| 2012-07-23 07:25 | pperisin | Note Added: 0002302 | |
| 2012-07-23 07:25 | pperisin | Status | closed => feedback |
| 2012-07-23 07:25 | pperisin | Resolution | fixed => reopened |
| 2012-07-23 09:54 | pperisin | Note Edited: 0002302 | |
| 2012-08-01 19:51 | yorik | Note Added: 0002306 | |
| 2012-08-01 19:51 | yorik | Status | feedback => closed |
| 2012-08-01 19:51 | yorik | Resolution | reopened => fixed |
