| 0000808 | Sketcher | Bug | public | 2012-08-01 19:02 | 2012-11-03 20:56 |
| Reporter | almesber | Assigned To | logari81 | ||
| Summary | 0000808: Sketcher: drawing arc over "imported" arc causes assertion failure | ||||
| Description | When trying to draw an arc on top of an arc obtained from another sketch with "Create an edge linked to an external geometry", I get the following assertion failure: freecad: /build/buildd/freecad-0.13/src/Mod/Sketcher/App/Sketch.cpp:432: int Sketcher::Sketch::checkGeoId(int): Assertion `geoId >= 0 && geoId < int(Geoms.size())' failed. I can reproduce it as follows: - start freecad on case.fcstd - select "Sketcher" - double-click "Sketch" - zoom/pan to lower left corner - draw new arc on the three points of the inner arc in this order: center, 6 o'clock, then 9 o'clock - freecad crashes | ||||
| Additional Information | FreeCAD 0.13, Libs: 0.13R1288 (Git) (from daily build for Ubuntu.) Running Ubuntu 12.04 LTS on x86_64. | ||||
| 2012-08-01 19:02 | almesber | New Issue | |
| 2012-08-01 19:02 | almesber | File Added: case.fcstd | |
| 2012-08-02 08:29 | logari81 | Assigned To | => logari81 |
| 2012-08-02 08:29 | logari81 | Status | new => assigned |
| 2012-08-02 08:29 | logari81 | Summary | sketch: drawing arc over "imported" arc causes assertion failure => Sketcher: drawing arc over "imported" arc causes assertion failure |
| 2012-08-06 21:26 | logari81 | Note Added: 0002311 | |
| 2012-11-03 20:56 | logari81 | Status | assigned => closed |
| 2012-11-03 20:56 | logari81 | Resolution | open => fixed |
| 2012-11-03 20:56 | logari81 | Fixed in Version | => 0.13 |
