| 0000827 | FreeCAD | Bug | public | 2012-09-08 15:22 | 2012-11-20 17:13 |
| Reporter | normandc | Assigned To | logari81 | ||
| Summary | 0000827: Sketch copy deletes all constraints | ||||
| Description | Previously when copying a sketch by copy-paste, all constraints and dimensions were copied to the new sketch. Now this is broken in the latest development release. Only sketch objects are preserved. This is a major usability setback which should be fixed before official release. Steps to reproduce: 1. Open attached .fcstd file 2. Select Sketch 3. Click on "Copy" in the standard toolbar 4. Click on "Paste" in the standard toolbar 5. Edit the new Sketch001 object. All the constraints are gone. | ||||
| Additional Information | OS: Ubuntu 12.04.1 LTS Platform: 64-bit Version: 0.13.1409 (Git) Branch: master Hash: 1d5f4147f1e91de14306339d3e4e83d5cae7b472 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 | ||||
2012-09-08 15:22
The problem actually is older than I thought. I uninstalled FreeCAD and installed the oldest .deb package I had in /var/cache/apt/archives, named freecad_0.13-git201208111837~precise1_amd64.deb. The bug is already there. |
I remembered I copied a precise PPA package to my UbuntuOne account for a forum member. I installed freecad_0.13-git201208060321~precise1_amd64.deb which is available at this link: http://ubuntuone.com/0qxLGSeraDzwui8W7fm2Oi About FreeCAD reports the following: Platform: Ubuntu 12.04.1 LTS (64-bit) Version: 0.13.1306 (Git) Branch: master Hash: eac9182ac95bc62101c33a8bf81957000d645e64 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 Published date: 2012/07/31 This version does not suffer from the bug. I wouldn't put too much confidence on the hash and git-commit being the right one, since I manually update this info once a day in the versioning.git launchpad branch. The bug would then have been introduced between 07/31 and 08/11. |
actually the constraints seem to be deleted but they are not deleted, there must be some acceptGeometry() call missing. |
Bug is still there. OS: Ubuntu 12.04.1 LTS Platform: 64-bit Version: 0.13.1652 (Git) Branch: master Hash: 1ca8f9562dff7783717a4b841d2e23f9459623e4 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.0 Actually jriegel mentioned in the forum that using the copy-paste tool was not a good idea. Should I close this bug and create a request for a specific copy sketch tool to be added to the Sketcher in (hopefully) v0.14? |
no, this report shouldn't be closed. It is in my TODO list. |
This bug is not directly related to the sketcher but when pasting from clipboard for the created sketcher copy the method onDocumentRestored() isn't called and thus acceptGeometry() isn't called either. |
git show cf49979 |
just re-openning for adding some more information on this. yes I was aware that the problem was that OnDocumentRestored wasn't called on paste/merge. Since we use OnDocumentRestored only for the sketcher, my original intention was to get rid of it completely and add some additional logic for handling missing external geometries / references. Anyway if it works now, lets let it for the moment. Btw we should also remove onFinishDuplicating since it should be replaced with OnDocumentRestored. |
| 2012-09-08 15:22 | normandc | New Issue | |
| 2012-09-08 15:22 | normandc | File Added: sketch_copy_broken.fcstd | |
| 2012-09-08 15:29 | normandc | Note Added: 0002361 | |
| 2012-09-08 15:41 | normandc | Note Added: 0002362 | |
| 2012-09-08 15:43 | normandc | Note Edited: 0002362 | |
| 2012-09-08 15:44 | normandc | Note Edited: 0002362 | |
| 2012-09-09 18:21 | logari81 | Status | new => assigned |
| 2012-09-09 18:21 | logari81 | Assigned To | => logari81 |
| 2012-09-09 18:24 | logari81 | Note Added: 0002364 | |
| 2012-11-20 03:00 | normandc | Note Added: 0002562 | |
| 2012-11-20 07:19 | logari81 | Note Added: 0002564 | |
| 2012-11-20 11:19 | wmayer | Note Added: 0002567 | |
| 2012-11-20 11:20 | wmayer | Note Added: 0002568 | |
| 2012-11-20 11:20 | wmayer | Status | assigned => resolved |
| 2012-11-20 11:20 | wmayer | Fixed in Version | => 0.13 |
| 2012-11-20 11:20 | wmayer | Resolution | open => fixed |
| 2012-11-20 11:34 | logari81 | Note Added: 0002569 | |
| 2012-11-20 11:34 | logari81 | Status | resolved => feedback |
| 2012-11-20 11:34 | logari81 | Resolution | fixed => reopened |
| 2012-11-20 17:13 | logari81 | Status | feedback => closed |
| 2012-11-20 17:13 | logari81 | Resolution | reopened => fixed |
