0000841FreeCADBugpublic2013-01-06 13:51
Reporterdanielfalck Assigned ToJriegel
PrioritynormalSeverityfeatureReproducibilityalways
Status closedResolutionfixed
Summary0000841: Polar Pattern doesn't work consistently - with Pads vs. Pockets
DescriptionI created a circle in Part Design/Sketcher and then made a Pad of it. I then selected a flat face and created a new sketch of a much smaller circle. This one, I made a pocket out of and had it go completely through the original object.
I tried to make a PolarPattern feature of the pocket and was able to use it to create a second pocket through the original part, using 2 Occurences and 360 degrees for the Angle, but couldn't create more Occurences. I got this error:
"Transformed objects are overlapping, try using a higher length or reducing the number of occurrences"
But, if the small pockets are pads instead, there is no problem doing a polar pattern with more than 2 occurences.
Thanks for the feature- when it's all worked out it will be very nice.
Dan
Additional InformationOS: Ubuntu 12.04.1 LTS
Platform: 64-bit
Version: 0.13.1488 (Git)
Hash: 065213f9bdd6e867e00ecc34d623728038c18469
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.2
danielfalck
2012-09-22 23:03
reporter   ~0002416
I noticed that if the pocket is completely through the parent part, this problem exists. If I use a specific length or 'Dimension' and make the pocket go through the part it PolarPattern works fine.
kwahooo
2012-09-23 05:49
reporter   ~0002417
I noticed similar issue http://forum.freecadweb.org/viewtopic.php?f=10&t=2951&start=50#p23327
Edit: (just checked) Also Linear pattern works for 'Dimension' but not for 'Through all'
jrheinlaender
2012-11-05 11:35
developer   ~0002490
IMHO this has been fixed with the latest merges by logari81 for Pocket. At least I couldn't reproduce the problems described above.
Could you please check again?
Jriegel
2012-12-20 19:33
administrator   ~0002693
Works for me (now). If no objection, I would close that one.
danielfalck
2013-01-05 19:28
reporter   ~0002800
This works for me too. Close this issue. Thanks.
2012-09-22 23:00 danielfalck New Issue
2012-09-22 23:03 danielfalck Note Added: 0002416
2012-09-23 05:49 kwahooo Note Added: 0002417
2012-09-23 05:51 kwahooo Note Edited: 0002417
2012-09-23 06:04 kwahooo Note Edited: 0002417
2012-11-05 11:35 jrheinlaender Note Added: 0002490
2012-12-20 19:33 Jriegel Note Added: 0002693
2012-12-20 19:33 Jriegel Status new => feedback
2012-12-20 19:33 Jriegel Status feedback => assigned
2012-12-20 19:33 Jriegel Assigned To => Jriegel
2013-01-05 19:28 danielfalck Note Added: 0002800
2013-01-06 13:51 Jriegel Status assigned => closed
2013-01-06 13:51 Jriegel Resolution open => fixed
