0000842FreeCADBugpublic2012-09-24 06:17
Reportercaterpillar86 Assigned To
PrioritynormalSeverityblockReproducibilitysometimes
Product Version0.12
Fixed in Version0.13
Summary0000842: FreeCAD 100%cpu usage at start
DescriptionEverytime I open FreeCAD on my desktop computer, I get 100% CPU usage
You can avoid that by not interacting with the Start page, opening a new work and then closing the tab of Start page.
System info:
Fedora 17 KDE 64bit kernel 3.5.4-1.fc17.x86_64
nVidia propertary drivers: 304.37
CPU: Phenom II X2 550BE
RAM: 16 gb
GPU: nVidia Geforce GTX 260
Jriegel
2012-09-23 08:16
administrator   ~0002419
Sounds like a problem of the WebKit component in Qt on Fedora.
Can not reproduce on my systems...
pperisin
2012-09-23 11:23
reporter   ~0002420
This is I think KDE issue - it happens on KDE 4.8 when using Oxygen theme - switch from Oxigen to something else:
pperisin
2012-09-23 11:26
reporter   ~0002421
actually it is KDE 4.9 issue:
http://forum.freecadweb.org/viewtopic.php?f=4&t=2815&p=22388&hilit=100+git#p22388
caterpillar86
2012-09-23 11:35
reporter   ~0002422
ok
pperisin
2012-09-23 19:12
reporter   ~0002424
I think this can be closed.
2012-09-23 07:57 caterpillar86 New Issue
2012-09-23 08:16 Jriegel Note Added: 0002419
2012-09-23 11:23 pperisin Note Added: 0002420
2012-09-23 11:26 pperisin Note Added: 0002421
2012-09-23 11:35 caterpillar86 Note Added: 0002422
2012-09-23 19:12 pperisin Note Added: 0002424
2012-09-24 06:17 wmayer Status new => closed
2012-09-24 06:17 wmayer Resolution open => no change required
2012-09-24 06:17 wmayer Fixed in Version => 0.13
