| 0000844 | Sketcher | Bug | public | 2012-09-24 07:40 | 2014-03-15 19:19 |
| Reporter | galou_breizh | Assigned To | wmayer | ||
| Target Version | 0.14 | ||||
| Summary | 0000844: Cannot use edge hidden by sketch axis as external geometry | ||||
| Description | Step to reproduce: - open FreeCAD - On the start page, category "Start a new project", choose Part Design - In the Comb View, click on Box - Select the visible face of the box and click on "Create sketch" - Click on "External geometry" icon (or hit "E") - try to select the left or bottom edge - I didn't succeed, in the task bar I can read "Not allowed: Unammed.Sketch.V_Axis" I think the V_Axis and H_Axis should be excluded from geometry matching when looking for an external constraint. | ||||
| Additional Information | FreeCAD 0.13, Libs: 0.13R1489 (Git) Ubuntu 12.04 64 bits FreeCAD from PPA | ||||
Any feedback from someone else? Thanks. |
I have the same issue. |
We need a filter or other defined precedence here. |
Another more elegand way is to use faces as external geos. They are mostly selectable. Also is this case only valid if you have the axis of the sketch exactly on the face edge. Then you can constrain against the axis.... |
FreeCAD: master 3ea41ff0 2014-03-15 19:53:14 Details Diff |
+ fixes 0000844: Cannot use edge hidden by sketch axis as external geometry |
Affected Issues 0000844 |
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/DrawSketchHandler.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/ViewProviderSketch.h | Diff File | ||
| 2012-09-24 07:40 | galou_breizh | New Issue | |
| 2012-10-05 18:28 | galou_breizh | Note Added: 0002439 | |
| 2012-10-06 11:42 | wmayer | Note Added: 0002440 | |
| 2012-11-15 17:27 |
Note Added: 0002527 | |
| 2012-11-15 17:27 |
Status | new => confirmed |
| 2012-11-15 18:06 |
Note Added: 0002530 | |
| 2012-11-15 18:12 |
Target Version | => 0.14 |
| 2014-03-15 19:19 | wmayer | Changeset attached | => FreeCAD Master master 3ea41ff0 |
| 2014-03-15 19:19 | wmayer | Assigned To | => wmayer |
| 2014-03-15 19:19 | wmayer | Status | confirmed => closed |
| 2014-03-15 19:19 | wmayer | Resolution | open => fixed |
