| 0000849 | FreeCAD | Feature | public | 2012-09-27 15:44 | 2013-07-01 09:09 |
| Reporter | pperisin | Assigned To | wmayer | ||
| Summary | 0000849: [Sketcher] Small inconsistency with update | ||||
| Description | Hi, when you are in sketch that already has it's feature (pad) and you move one of it's points, it's feature (pad) will auto update. However, if you double click on a dimension and modify it's value, sketch will update but feature (pad) will not. This seems little inconsistent. Regards, Petar | ||||
| Additional Information | 1 - Create new sketch, 2 - place rectangle, 3 - add dimension constraint to one side, 4 - close sketch 5 - create pad 6 - reopen sketch now: 7a - move one point - Pad will update on mouse release of a drag 7b - double click on a dimension created in 3 and modify it - Pad will not update | ||||
I think this could be fixed by adding, so that the document recomputes Gui::Command::updateActive(); after line 126 in EditDatumDialog.cpp in setcher |
git show f5d091f |
| 2012-09-27 15:44 | pperisin | New Issue | |
| 2012-10-04 19:38 | mrlukeparry | Note Added: 0002438 | |
| 2013-06-30 12:48 | wmayer | Status | new => assigned |
| 2013-06-30 12:48 | wmayer | Assigned To | => wmayer |
| 2013-07-01 09:09 | wmayer | Note Added: 0003303 | |
| 2013-07-01 09:09 | wmayer | Status | assigned => closed |
| 2013-07-01 09:09 | wmayer | Resolution | open => fixed |
| 2013-07-01 09:09 | wmayer | Fixed in Version | => 0.14 |
