| 0000862 | Draft | Bug | public | 2012-10-30 09:40 | 2013-06-15 18:04 |
| Reporter | wmayer | Assigned To | yorik | ||
| Summary | 0000862: Draft toolbar doesn't disappear when switching workbenches | ||||
| Description | Steps to reproduce: * From e.g. Part workbench go to Draft * Go to Part * Go to Draft * Go to Part Now, there is a tool bar (Draft Snap) that doesn't disappear but the others do. And when checking the available tool bars in the View menu the Draft Snap isn't listed there. | ||||
Actually that was at first the intended behaviour (that you could still use the draft snaps in other modules). The other problem (when switching workbenches, the name of the draft toolbar doesn't appear in the list) I couldn't solve yet... But actually that draft toolbar is at the moment a quick hack (all made in pyqt), and needs to be redone properly, using FreeCAD commands. This will solve both problems at once. I'll schedule it for after 0.13... |
git show 5a04ade should fix it. The snap toolbar now also appears in the Menu. And there is a translation fix. |
Aah I see, the trick was to specify its parent! Excellent, thanks for the fix Werner |
| 2012-10-30 09:40 | wmayer | New Issue | |
| 2012-10-30 09:40 | wmayer | Status | new => assigned |
| 2012-10-30 09:40 | wmayer | Assigned To | => yorik |
| 2012-10-30 10:44 | yorik | Note Added: 0002474 | |
| 2012-10-30 10:45 | yorik | Target Version | => 0.14 |
| 2012-10-30 10:46 | yorik | Project | FreeCAD => Draft |
| 2013-06-13 18:35 | wmayer | Note Added: 0003201 | |
| 2013-06-13 18:35 | wmayer | Status | assigned => resolved |
| 2013-06-13 18:35 | wmayer | Fixed in Version | => 0.14 |
| 2013-06-13 18:35 | wmayer | Resolution | open => fixed |
| 2013-06-15 17:23 | wmayer | Status | resolved => closed |
| 2013-06-15 18:04 | yorik | Note Added: 0003218 |
