| 0000864 | FreeCAD | Bug | public | 2012-10-30 21:56 | 2013-06-29 15:02 |
| Reporter | pervices | Assigned To | |||
| Summary | 0000864: Skin remains when cutting rectangle | ||||
| Description | Using git version: FreeCAD 0.13, Libs: 0.13R1535 (Git: 8de40bc3a) When cutting a rectangular shape out, part of the object is left behind (i.e., not a clean cut). Confirmed on another computer. Result in attached file. Tools used when producing result: 1. Use DWire to make shape 2. Place circles in required locations 3. Place rectangle in required location 4. Extrude all elements 5. Select main shape, select cut out shape, use the "Make a cut" button to remove selected cut out shape 6. Works for all elements except for the rectangle | ||||
2012-10-30 21:56
Can confirm the problem, but put it on low prio. This kind of modeling (CSG) is not preferred and known to lead to problems due to easely count up small errors. Please use PartDesign Sketcher and Pad/Pocket for such a modeling. |
Using OCC 6.5 there issue is still there but when switching to OCC 6.6 it disappears. So, it was actually an OCC bug |
| 2012-10-30 21:56 | pervices | New Issue | |
| 2012-10-30 21:56 | pervices | File Added: NOCTAR-bracket.FCStd | |
| 2012-10-31 05:20 |
Note Added: 0002478 | |
| 2012-10-31 05:20 |
Reproducibility | have not tried => always |
| 2012-10-31 05:20 |
| 2013-06-29 15:02 | wmayer | Note Added: 0003294 | |
| 2013-06-29 15:02 | wmayer | Status | acknowledged => closed |
| 2013-06-29 15:02 | wmayer | Resolution | open => fixed |
| 2013-06-29 15:02 | wmayer | Fixed in Version | => 0.14 |
