0000882DraftBugpublic2012-11-23 16:42
Reportermarbangens Assigned Towmayer
Product Version0.12
Fixed in Version0.13
Summary0000882: Undo the wire tool makes FreeCAD crash on windows xp sp3
DescriptionI followed the basic modeling tutorial and discoverer if the undo button related to the wire tool was pressed to get to the first action. Application crashed every time using windows xp sp3. This can be my OS fucking up, but it's worth checking out if you planing on windows support.
2012-11-19 08:30
administrator   ~0002555
Could you be more precise? What are the exact steps you do? And which version do you use?
marbangens
2012-11-19 11:35
reporter   ~0002556
Okej Im using FreeCAD 0.12 revision 5286
I have the Swedish button names, so I'll try my best to translate them.
Now I have opened FreeCAD
1. I click create new
2. select part workbench NOT part design to be extra clear
3. I click on the create box icon
4. click on the new box in the project tree
5. swap to data on the bottom of that side panel
6. I type in 50x50x750 and zoom out.
7. create another box with 40x40x750.
8. select Box first and the Box001 with the control key and make the cut operation.
10. now I switch to back view using the 4 key. I looks like an F
11. switch to Draft workbench.
12. press the button that says "none" and then the XY button.
13. I select the wire tool. (this one https://sourceforge.net/apps/mediawiki/free-cad/index.php?title=Draft_Wire)
14. select 2 points with it.
15. I press the undo button in the top panel. the Swedish name is Ă…ngra
Crash!!
2012-11-19 11:42
marbangens
2012-11-19 11:46
reporter   ~0002557
the button that cases the crash is shown in the picture.
and I have reinstalled FreeCAD, It didn't help.
2012-11-19 11:48
administrator   ~0002558
OK, confirmed. Thanks for the precise description.
2012-11-19 11:58
administrator   ~0002559
The crash only happens in 0.12. In 0.13 it's fixed. So can you move to the newer version please?
2012-11-18 18:52 marbangens New Issue
2012-11-19 08:30 wmayer Note Added: 0002555
2012-11-19 11:35 marbangens Note Added: 0002556
2012-11-19 11:42 marbangens File Added: cad.jpg
2012-11-19 11:46 marbangens Note Added: 0002557
2012-11-19 11:48 wmayer Note Added: 0002558
2012-11-19 11:58 wmayer Note Added: 0002559
2012-11-20 08:08 wmayer Status new => resolved
2012-11-20 08:08 wmayer Fixed in Version => 0.13
2012-11-20 08:08 wmayer Resolution open => no change required
2012-11-20 08:08 wmayer Assigned To => wmayer
2012-11-23 16:42 wmayer Status resolved => closed
