0000898DraftBugpublic2012-12-18 15:45
Reportermore10 Assigned Toyorik
PrioritynormalSeveritymajorReproducibilityhave not tried
Product Version0.12
Fixed in Version0.13
Summary0000898: Distorted dxf 2dview
DescriptionI have created a 3D drawing by importing a 2D dwg, and extruding it´s parts. I have changed the placement of the imported drawing so that the box is shown standing up instead of laying down.
I order to make 2D plans I create 2Dviews i draft tool and export them as dxf. I change the projection of the 2dview to be x instead of z.
I open the dxf in LibreCAD to dimension it. Dimensions are different in this dxf compared to the original. Either I am doing something wrong, or I have found a bug. I cannot dimension in FreeCAD because I get lots of errors, and the model starts flickering. So I have no idea where the problem is.
The 3D model is attached, as well as original and exported dxf files.
Additional InformationSee the thread https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=3262
I run FreeCAD in Ubuntu on a VmWare Workstation 8.
OS: Ubuntu 12.04.1 LTS
Platform: 32-bit
Version: 0.13.1699 (Git)
Hash: 55117489b2c7860780e0c367fdc6703364712c8b
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
chamber original.pdf (3,597 bytes)
2012-12-04 22:13
chamber original.dxf (57,056 bytes)
2012-12-04 22:14
chamber 2dview.pdf (6,283 bytes)
2012-12-04 22:15
chamber 2dview.dxf (25,792 bytes)
2012-12-04 22:15
yorik
2012-12-05 11:38
administrator   ~0002611
hi,
honestly i don't know what can have happened between the 2 dxf versions. What I can tell you is that dxf files are imported 1:1 in freecad, there is no translation, rotation or whatsoever. Same goes when exporting. I see that your second dxf file, if you zoom in very close, is not very precise... Maybe that is where the problem lies? Anyway, without seeing the freecad file, it is hard to tell.
All I can tell is that the original dxf imports at correct scale in FreeCAD...
Can you attach the FCStd file?
more10
2012-12-05 14:00
reporter   ~0002614
There is no FCStd file. I just opened the dxf and made dimensions.
I have checked the dxf in AutoCAD 2000. Adding dimensions in AutoCAD has the same problem. An additional problem is that the lower right corner is not easily selectable for a dimension, I had to choose intersection explicitly in order to choose it correctly.
yorik
2012-12-18 15:45
administrator   ~0002664
Okay, I'll close this report then, since I don't see anything required from us, since both submitted dxf files import correctly. Don't hesitate to reopen this issue if you can identify a problem specific to FreeCAD.
2012-12-04 22:12 more10 New Issue
2012-12-04 22:12 more10 File Added: chamber original.pdf
2012-12-04 22:13 more10 File Added: chamber original.dxf
2012-12-04 22:14 more10 File Added: chamber 2dview.pdf
2012-12-04 22:15 more10 File Added: chamber 2dview.dxf
2012-12-04 22:15 more10 File Added: Screenshot from 2012-11-28 15:50:24.png
2012-12-05 11:38 yorik Note Added: 0002611
2012-12-05 11:39 yorik Assigned To => yorik
2012-12-05 11:39 yorik Status new => feedback
2012-12-05 13:50 yorik Project FreeCAD => Draft
2012-12-05 14:00 more10 Note Added: 0002614
2012-12-18 15:45 yorik Note Added: 0002664
2012-12-18 15:45 yorik Status feedback => closed
2012-12-18 15:45 yorik Resolution open => no change required
2012-12-18 15:45 yorik Fixed in Version => 0.13
