| 0000009 | FreeCAD | Bug | public | 2009-09-28 10:34 | 2009-12-21 09:53 |
| Reporter | Assigned To | wmayer | |||
| Priority | low | Severity | minor | Reproducibility | unable to reproduce |
| Platform | Linux | OS | Fedora | OS Version | 11 |
| Product Version | 0.8 | ||||
| Summary | 0000009: configure fails at boost on Fedora 11 | ||||
| Description | FreeCAD-0.8.2237 checking for xercesc/framework/XMLBuffer.hpp... yes checking whether xerces lib is available... yes checking for boost... configure: error: failed $ rpm -qa boost boost-1.37.0-6.fc11.i586 $ cat /tmp/conftest.cpp /* confdefs.h. */ #define PACKAGE_NAME "FreeCAD" #define PACKAGE_TARNAME "FreeCAD" #define PACKAGE_VERSION "0.8.2237" #define PACKAGE_STRING "FreeCAD 0.8.2237" #define PACKAGE_BUGREPORT "wmayer@users.sourceforge.net" #define PACKAGE "FreeCAD" #define VERSION "0.8.2237" #define STDC_HEADERS 1 #define HAVE_SYS_TYPES_H 1 #define HAVE_SYS_STAT_H 1 #define HAVE_STDLIB_H 1 #define HAVE_STRING_H 1 #define HAVE_MEMORY_H 1 #define HAVE_STRINGS_H 1 #define HAVE_INTTYPES_H 1 #define HAVE_STDINT_H 1 #define HAVE_UNISTD_H 1 #define HAVE_ISTREAM 1 #define HAVE_OSTREAM 1 #define HAVE_ISTREAM 1 #define HAVE_FSTREAM 1 #define HAVE_IOS 1 #define HAVE_IOMANIP 1 #define HAVE_IOSTREAM 1 #define HAVE_IOMANIP_H 1 #define HAVE_LIMITS_H 1 #define HAVE_VALUES_H 1 #define HAVE_FLOAT_H 1 #define HAVE_BITS_SIGSET_H 1 #define HAVE_SYS_TYPES_H 1 #define HAVE_SYS_SELECT_H 1 #define HAVE_SYS_MMAN_H 1 #define HAVE_SSTREAM 1 #define HAVE_NAMESPACES #define HAVE_STD_IOSTREAM #define HAVE_DLFCN_H 1 #define LT_OBJDIR ".libs/" #define HAVE_GETENVIRONMENTVARIABLE 1 #define HAVE_GL_GL_H 1 #define HAVE_QGLFORMAT_EQ_OP 1 #define HAVE_QGLFORMAT_SETOVERLAY 1 #define HAVE_QGLWIDGET_SETAUTOBUFFERSWAP 1 #define HAVE_QT_KEYPAD_DEFINE 1 #define HAVE_QWIDGET_SHOWFULLSCREEN 1 #define HAVE_SYS_TYPES_H 1 #define USE_STD_IOSTREAM 1 /* end confdefs.h. */ #include <boost/program_options.hpp> int main () { namespace po = boost::program_options; po::options_description generic("Generic options"); generic.add_options() ("version,v", "print version string") ("help", "produce help message"); ; return 0; } $ g++ -o conftest -g -O2 -I/usr/include -L/usr/lib conftest.cpp -lboost_program_options-mt /usr/lib/libboost_program_options-mt.so: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::__ostream_insert<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*, int)@GLIBCXX_3.4.9' /usr/lib/libboost_program_options-mt.so: undefined reference to `std::ctype<char>::_M_widen_init() const@GLIBCXX_3.4.11' collect2: ld returned 1 exit status | ||||
Does this solve the problem? g++ -o conftest -g -O2 -I/usr/include -L/usr/lib conftest.cpp -lboost_program_options-mt -lstdc++ |
doesn't appear to change things: FreeCAD-0.8.2237]$ g++ -o conftest -g -O2 -I/usr/include -L/usr/lib conftest.cpp -lboost_program_options-mt -lstdc++ /usr/lib/libboost_program_options-mt.so: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::__ostream_insert<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*, int)@GLIBCXX_3.4.9' /usr/lib/libboost_program_options-mt.so: undefined reference to `std::ctype<char>::_M_widen_init() const@GLIBCXX_3.4.11' collect2: ld returned 1 exit status |
Hmm, I'm not quite sure but for me it sounds like a problem with boost or gcc. Did you install the boost stuff from the Fedora package repositories or did you build them on your own? Which version of gcc was used to build the boost libs and which version of gcc do you use to try to build FreeCAD? |
boost is from the fedora, and I don't know what version of gcc they used in the build for boos $ rpm -qa gcc gcc-4.4.1-2.fc11.i586 |
Searching in the web for "__ostream_insert" I've found some advices you may check on your system: * is libstdc++ installed, normally this should be version 6.x but you can check libboost_program_options-mt.so with the tool ldd on which it depends on, for furhter info see: http://www.linuxquestions.org/questions/programming-9/compile-error-undefined-reference-to-stdbasicostream-669541/ * have a look to: http://www.nabble.com/compilation-errors-on-rhel-5-td20695159.html * http://www.linuxquestions.org/questions/fedora-35/how-to-install-gcc-4.1-with-fedora-10-735162/ |
ok ... will do I submitted this as a configure bug, because in theory, configure should be able to safely navigate common platform configurations without these kinds of failures. |
I didn't get any further feedback for more than three months. So, there is nothing further I can do. |
| 2009-09-28 10:34 |
New Issue | |
| 2009-09-28 10:34 |
Status | new => assigned |
| 2009-09-28 10:34 |
Assigned To | => wmayer |
| 2009-09-28 10:36 |
Product Version | => 0.8 |
| 2009-09-28 10:40 | wmayer | Note Added: 0000001 | |
| 2009-09-28 10:42 | wmayer | Note Added: 0000004 | |
| 2009-09-28 10:42 | wmayer | Note Added: 0000006 | |
| 2009-09-28 10:42 | wmayer | Note Added: 0000008 | |
| 2009-09-28 10:43 | wmayer | Note Added: 0000010 | |
| 2009-09-28 10:43 | wmayer | Note Added: 0000011 | |
| 2009-12-21 09:53 | wmayer | Note Added: 0000076 | |
| 2009-12-21 09:53 | wmayer | Status | assigned => closed |
| 2009-12-21 09:53 | wmayer | Resolution | open => not fixable |
