| 0000918 | FreeCAD | Bug | public | 2012-12-18 20:44 | 2014-09-22 13:33 |
| Reporter | beckcb2004 | Assigned To | |||
| Summary | 0000918: Problem when compile FreeCAD. Fails on Ubuntu 13.04.Amd64. Multiple Python versions. (2.7 and 3). | ||||
| Description | Problem: Problem when compile FreeCAD. Fails on Ubuntu 13.04. Multiple Python versions. (2.7 and 3). I run alpa releas of Ubuntu version 13.04, and downloads daily build of FreeCAD via git. I suppose the error occurs because of duplicate versions of Python interpreter. Both are devel versions of libraries installed cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ python Python 2.7.3 (default, Dec 12 2012, 19:00:09) [GCC 4.7.2] on linux2 cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$python3 Python 3.3.0 (default, Dec 12 2012, 19:03:06) [GCC 4.7.2] on linux I suppose this will be a problem on coming releases due to the following: kde uses Python 3 coin uses Python 2.7 I have tried different parameters on the cmake and ./configure to specify that I want Python 2.7 but without luck. Could you please provide a description on how to set parameters for compiling, and post it on freecad wiki, How to properly select the correct Python version when compiling. ================ I do the following to get error: git pull cmake . make or ./configure The following errors occurs: When running freecad CMAKE: ============================ cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$cmake ../freecad.git . This runs ok through. cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ make [ 0%] Building CXX object src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/coin_wrap.cpp.o /LxSrc/Src.dwl/freecad.git/src/3rdParty/Pivy-0.5/coin_wrap.cpp:145:20: fatal error: Python.h: No such file or directory compilation terminated. make[2]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/coin_wrap.cpp.o] Error 1 make[1]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/all] Error 2 make: *** [all] Error 2 cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ =================== When running ./configure:checking for python script directory... ${prefix}/lib/python2.7/site-packages checking for python extension module directory... ${exec_prefix}/lib/python2.7/site-packages checking Python.h usability... no checking Python.h presence... no checking for Python.h... no configure: error: **** Cannot find Python2.7 devel files. **** cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ ========================== Thank you very much for your time, and merry Christmas to all of you out there. Christian. | ||||
"coin uses Python 2.7" Should not say coin but python-pivy. python-pivy depends python(<2.8) depends python(>=2.7) |
> Problem when compile FreeCAD. Fails on Ubuntu 13.04. Multiple Python versions. (2.7 and 3). Having python 2 & 3 installed at the same time shouldn't be a problem. > Python.h: No such file or directory It seems you haven't installed libpython2.7-dev |
Thank you for your quick response. The libpython2.7-dev package is already installed as shown below. As of Wednesday 12/19/2012 21:00: To verify this problem I will document a fresh install as follows: I will do a apt-get purge on libpython2.7-dev and then install libpython2.7-dev again, before I do another freecad git pull, cmake ../freecad.git . and make I will also do a ./configure to show the error coming up. ========== I list the already installed package: cbe@B9Lap:~$ dpkg -l libpython2.7-dev Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==============-============-============-================================= ii libpython2.7-d 2.7.3-12ubun amd64 Header files and a static library cbe@B9Lap:~$ cbe@B9Lap:~$ =============== Here I do a purge on libpython2.7-dev from within synaptic: (Reading database ... 598491 files and directories currently installed.) Removing python-all-dev ... Removing python-dev ... Removing libpython-dev:amd64 ... Removing python2.7-dev ... Processing triggers for man-db ... debconf: unable to initialize frontend: Dialog debconf: (Dialog frontend requires a screen at least 13 lines tall and 31 columns wide.) debconf: falling back to frontend: Readline (Reading database ... 598467 files and directories currently installed.) Removing libpython2.7-dev:amd64 ... Processing triggers for man-db ... debconf: unable to initialize frontend: Dialog debconf: (Dialog frontend requires a screen at least 13 lines tall and 31 columns wide.) debconf: falling back to frontend: Readline Successfully applied all changes. You can close the window now. ============= Then I installed python-all-dev again: Setting up libpython2.7-dev:amd64 (2.7.3-12ubuntu2) ... Setting up libpython-dev:amd64 (2.7.3-10ubuntu3) ... Setting up python2.7-dev (2.7.3-12ubuntu2) ... Setting up python-dev (2.7.3-10ubuntu3) ... Setting up python-all-dev (2.7.3-10ubuntu3) ... Successfully applied all changes. You can close the window now. ============== Now a fresh version of the dev library is installed inclusive Python.h file: cbe@B9Lap:~$ cbe@B9Lap:~$ locate Python.h ... ... /usr/include/python2.7/Python.h /usr/include/python3.3dm/Python.h /usr/include/python3.3m/Python.h ... ... cbe@B9Lap:~$ ======== Then I do another "git pull" to get a fresh freecad version: cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ git pull .... .... cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ cd ../free*bui* cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ cmake ../freecad.git . -- prefix: /usr/local .... .... -- Configuring done -- Generating done -- Build files have been written to: /LxSrc/Src.dwl/freecad-build cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ Everything looks nice and correct, I try to do make and get the error: =========== cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ make [ 0%] Building CXX object src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/coin_wrap.cpp.o /LxSrc/Src.dwl/freecad.git/src/3rdParty/Pivy-0.5/coin_wrap.cpp:145:20: fatal error: Python.h: No such file or directory compilation terminated. make[2]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/coin_wrap.cpp.o] Error 1 make[1]: *** [src/3rdParty/Pivy-0.5/CMakeFiles/coin.dir/all] Error 2 make: *** [all] Error 2 cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ =================== If I do the ./configure command from freecad.git directory I get the error as follows: checking for inflate in -lz... yes checking for a Python interpreter with version >= 2.5... python checking for python... /usr/bin/python checking for python version... 2.7 checking for python platform... linux2 checking for python script directory... ${prefix}/lib/python2.7/site-packages checking for python extension module directory... ${exec_prefix}/lib/python2.7/site-packages checking Python.h usability... no checking Python.h presence... no checking for Python.h... no configure: error: **** Cannot find Python2.7 devel files. **** cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ ======================== And from here I am totally lost. Since I have installed a fresh version of the python development environment including libpython2.7-dev. So what could be wrong? Something pointing in wrong direction? or environment variables set wrong to look in wrong directories? Or conflict between Python 2.7 and Pyton3? Or should I override with --Python-lib, --Python-include.... or whatever from the cmake command? I dont know ;-) Is there a download repository for daily-build of freecad on Ubuntu 13.04 (Raring)? Well this was a lot of output, to your information. If you can point me in right direction I would be grateful. And once again thank's for your time. Regards Christian. |
Hello again. Today I did a apt-get purge on the cmake package, and installed once again hen I did another freecad git pull. Now CMAKE reports a more informative error message: ================================== cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ git pull Already up-to-date. cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ cd ../fr*b bash: cd: ../fr*b: No such file or directory cbe@B9Lap:/LxSrc/Src.dwl/freecad.git$ cd .. cbe@B9Lap:/LxSrc/Src.dwl$ cd fr*b* cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ cmake ../freecad.git . -- prefix: /usr/local -- datadir: data -- docdir: doc -- includedir: include CMake Error at /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:97 (message): Could NOT find PythonLibs (missing: PYTHON_INCLUDE_DIRS) Call Stack (most recent call first): /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:291 (_FPHSA_FAILURE_MESSAGE) /usr/share/cmake-2.8/Modules/FindPythonLibs.cmake:208 (FIND_PACKAGE_HANDLE_STANDARD_ARGS) CMakeLists.txt:174 (find_package) -- Configuring incomplete, errors occurred! cbe@B9Lap:/LxSrc/Src.dwl/freecad-build$ cmake ../freecad.git . =============================== This launchpad ppa user also has problems with daily-build (about 14 hours ago) See following URL: https://launchpadlibrarian.net/126185071/buildlog_ubuntu-raring-amd64.freecad_0.13-git201212192148~raring1_FAILEDTOBUILD.txt.gz /usr/include/python2.7/Python.h:8:22: fatal error: pyconfig.h: No such file or directory compilation terminated. =============================== Could this be related to the earlier bug reported on following URL?: Debian Bug report logs - #677598 find_package: PythonInterp and PythonLibs are conflicting If you play with the attached CMakeLists.txt file on a debian/sid system you'll notice that PythonInterp find python 2.7 while PythonLibs always find 3.2. -- Could NOT find PythonLibs (missing: PYTHON_LIBRARIES PYTHON_INCLUDE_DIRS) Look at following URL: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=677598 =================== Just some additional information Thanks Christian. |
Hunt bugs on Ubuntu Version that early makes not much sense... A month before release we can talk again. |
Ok. Thanks for your response and time anyway. I will await further actions. Case closed. Happy Christmas and Bye from here ;-) |
Maybe you can upload the config.log file from your automake/configure attempt. This should have more details of what could have gone wrong. |
Hello again I send you the output files from freecad configuration using cmake as attachments. I didn't find any upload commands on sourceforge, so I send it on your email account. One of the files shows program code as output (at the end of the file) There is also a lot of uninitiated variables shown. I did the cmake command as follows: cmake --debug-output --trace --warn-uninitialized --warn-unused-vars --check-system-vars ../freecad.git . 2>&1 | tee cmake.cbe.out.txt Attached is 3 files: CMakefiles/CMakeError.log CMakefiles/CMakeOutput.log cmake.cbe.out.txt Hopefully you can get some useful information. regards Christian |
2012-12-21 07:57
2012-12-21 07:59
2012-12-21 07:59
I'm not familiar with the output of cmake. There I didn't find a hint why it fails to detect the python headers. So, can you please try again with ./configure where you also get a problem with python? Therefore I need the file config.log which contains all the relevant information. BTW, on my private email I didn't get a message. |
This is the relevant section: configure:23430: checking Python.h usability configure:23430: g++ -c -g -O2 -I/usr/include/python2.7 conftest.cpp >&5 In file included from conftest.cpp:87:0: /usr/include/python2.7/Python.h:8:22: fatal error: pyconfig.h: No such file or directory If you search for packages containing pyconfig.h on versions prior to Raring you'll find it in python2.7-minimal. But the same package for Raring doesn't have this file. The package libpython2.7-dev provides this file but in another directory /usr/include/i386-linux-gnu/python2.7 (32-bit) or /usr/include/x86_64-linux-gnu/python2.7 (64-bit). Now the problem is that this path isn't listed as include directory when doing the tests with ./configure or cmake and hence the failure. |
I saw the same thin in 32bit version. Luke posted on the forum about the problem and noted a missing symlink. I added the symlink and still get the error from cmake but it did compile. http://forum.freecadweb.org/viewtopic.php?f=4&t=3987 |
| 2012-12-18 20:44 | beckcb2004 | New Issue | |
| 2012-12-18 20:59 | beckcb2004 | Note Added: 0002665 | |
| 2012-12-19 11:31 | wmayer | Note Added: 0002667 | |
| 2012-12-19 19:27 | beckcb2004 | Note Added: 0002673 | |
| 2012-12-20 12:16 | beckcb2004 | Note Added: 0002677 | |
| 2012-12-20 18:51 |
Note Added: 0002687 | |
| 2012-12-20 18:51 |
Priority | normal => low |
| 2012-12-20 18:51 |
Status | new => feedback |
| 2012-12-20 20:43 | beckcb2004 | Note Added: 0002710 | |
| 2012-12-20 21:39 | wmayer | Note Added: 0002720 | |
| 2012-12-21 07:34 | beckcb2004 | Note Added: 0002738 | |
| 2012-12-21 07:57 |
File Added: cmake.cbe.out.txt.zip | |
| 2012-12-21 07:59 |
File Added: CMakeError.log | |
| 2012-12-21 07:59 |
File Added: CMakeOutput.log | |
| 2012-12-21 10:17 | wmayer | Note Added: 0002742 | |
| 2012-12-22 09:51 | wmayer | Note Added: 0002748 | |
| 2013-04-28 11:01 | sliptonic | Note Added: 0003119 | |
| 2014-09-22 13:33 | shoogen | Status | feedback => closed |
| 2014-09-22 13:33 | shoogen | Resolution | open => won't fix |
