| 0000926 | FreeCAD | Feature | public | 2012-12-21 15:30 | 2014-03-29 19:49 |
| Reporter | nikospap | Assigned To | yorik | ||
| Summary | 0000926: spreadsheet, like, basic culculations in constrains, placement etc | ||||
| Description | This could be a nice little feature that saves you cklickings and time. Example: Let's say I want to create a hollow frame, and its external dimentions would be 100x100, while the thickness of its sizes would be 20. I want to design that box (in freecad) out of 4 pieces, like I would in real life (and then stick them together). So the dimensions (2D) of the two pieces would be 100x20 while the other two would be 20x80 (100-20, |_| ) When giving the constrains for the two smaller pieces, it would be helpful, if I could just type in the pop-up =100-20 (like I would in a spreadsheet application) instead of using an extenal calculator, copying the numbers there, doing the calculations, there, and then typing the result, back, in Freeecad. 80 Of course, the numbers, in the example above, are simple, but what if I had to copy these diamentions? =(1257,65-2*(11,9-1,3))/2 | ||||
As you, probably, have noticed, my simple calculations, above, are wrong (not deliberatly). So, it would be helpful if i could, later on, fix them in Freecad. The dimentions for the smaller pieces, would need to be fixed from =100-20 to =100-2*20 Therefore, the "=100-20" part should still, somehow, show up everytime you double cklick on that constrain, so as to be easily changed, if necessery. |
I will add this feature to the spreadsheet module (ability to "drive" a property of an object from the spreadsheet) |
FreeCAD: master 92439234 2014-03-29 20:16:04 Details Diff |
Spreadsheet: property controller - fixes 0000926 Added a new object and tool called property controller, which must be added to a spreadsheet and gives the value of a cell to a property of an object. |
Affected Issues 0000926 |
| mod - src/Mod/Spreadsheet/InitGui.py | Diff File | ||
| mod - src/Mod/Spreadsheet/Resources/Spreadsheet.qrc | Diff File | ||
| add - src/Mod/Spreadsheet/Resources/icons/SpreadsheetPropertyController.svg | Diff File | ||
| mod - src/Mod/Spreadsheet/Spreadsheet.py | Diff File | ||
| mod - src/Mod/Spreadsheet/Spreadsheet_rc.py | Diff File | ||
| 2012-12-21 15:30 | nikospap | New Issue | |
| 2012-12-21 15:46 | nikospap | Note Added: 0002745 | |
| 2014-03-11 02:04 | yorik | Note Added: 0004417 | |
| 2014-03-11 02:04 | yorik | Assigned To | => yorik |
| 2014-03-11 02:04 | yorik | Status | new => assigned |
| 2014-03-29 19:49 | yorik | Changeset attached | => FreeCAD Master master 92439234 |
| 2014-03-29 19:49 | yorik | Status | assigned => closed |
| 2014-03-29 19:49 | yorik | Resolution | open => fixed |
