| 0000929 | FreeCAD | Bug | public | 2012-12-23 16:18 | 2013-01-02 08:15 |
| Reporter | mrlukeparry | Assigned To | logari81 | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Summary | 0000929: Using External Entities in Sketcher creates false pad / pocket | ||||
| Description | If you create a fully closed shape inside Sketcher using external entities, these create incorrect pad / pocket with tearing - the result extrusion shape is incorrect. I don't think these are included when creating the complete wire that is used in the sketch - maybe because the sketcher indexes for these edges are less than zero. I cannot confirm if this happen every time, but I noticed this today. I think this really should be fixed before the 0.13 release if it can be confirmed by other users. - 0.13 -dev Windows | ||||
could you provide an example file? |
External geometry won't show up in a sketch. Its only a helper for external references and no actual geometry... |
That's fine - but it should be made clear in the documentation. Although if that is true, the pad operation should have detected an open wire... |
Yes, but detecting all kinds of erroneous shape forms is a quest on its own :) |
| 2012-12-23 16:18 | mrlukeparry | New Issue | |
| 2012-12-27 20:16 | logari81 | Note Added: 0002764 | |
| 2012-12-30 15:40 |
Note Added: 0002767 | |
| 2012-12-30 15:40 |
Assigned To | => logari81 |
| 2012-12-30 15:40 |
Status | new => feedback |
| 2012-12-30 17:30 | mrlukeparry | Note Added: 0002769 | |
| 2012-12-30 22:20 |
Note Added: 0002771 | |
| 2013-01-02 08:15 |
Status | feedback => closed |
| 2013-01-02 08:15 |
Resolution | open => no change required |
