| 0000931 | FreeCAD | Feature | public | 2012-12-23 20:43 | 2013-07-09 15:03 |
| Reporter | thatcadguy | Assigned To | wmayer | ||
| Summary | 0000931: Can't change STEP/IGES export units through Python interface | ||||
| Description | By default, STEP/IGES export is in mm. You can change the units by going to Preferences->Part design->Export->Units for export of STEP/IGES. When this happens, DlgSettingsGeneral::saveSettings() is called (/Mod/Part/Gui/DlgSettingsGeneral.cpp) and it does 2 things: - Change the units in BaseApp/Preferences/Mod/Part - Change the units in OpenCASCADE's settings: write.step.unit and write.iges.unit Currently, you can only do the 1st part from Python: params = FreeCAD.ParamGet('User parameter:BaseApp/Preferences/Mod/Part') params.SetInt('Unit',unit) However, without doing the 2nd part (e.g. not changing the setting via dialog and only doing the above 2 lines in a script), the STEP/IGES files are still exported as mm. In order to remedy this, I have constructed the following from DlgSettingsGeneral::saveSettings(): static PyObject * setExportUnits(PyObject *self, PyObject *args) { int unit; if (!PyArg_ParseTuple(args, "i", &unit)) return NULL; Base::Reference<ParameterGrp> hGrp = App::GetApplication().GetUserParameter() .GetGroup("BaseApp")->GetGroup("Preferences")->GetGroup("Mod/Part"); hGrp->SetInt("Unit", unit); switch (unit) { case 1: Interface_Static::SetCVal("write.iges.unit","M"); Interface_Static::SetCVal("write.step.unit","M"); break; case 2: Interface_Static::SetCVal("write.iges.unit","IN"); Interface_Static::SetCVal("write.step.unit","IN"); break; default: Interface_Static::SetCVal("write.iges.unit","MM"); Interface_Static::SetCVal("write.step.unit","MM"); break; } } The following should be added to the Python methods registration table: {"setExportUnits", setExportUnits, METH_VARARGS, "setExportUnits(unit) -- Set units for exporting STEP/IGES files"} Not sure where this function should be added, I was thinking /src/Mod/Part/App/AppPartPy.cpp. Anyway, the function should work and is straightforward, I'd appreciate it if someone more familiar with FreeCAD's code as a whole could look it over and add it to the appropriate place. Thanks! | ||||
The following includes should be present as well: #include <Interface_Static.hxx> #include <Base/Parameter.h> #include <App/Application.h> |
git show a66d944 |
| 2012-12-23 20:43 | thatcadguy | New Issue | |
| 2012-12-23 20:55 | thatcadguy | Note Added: 0002761 | |
| 2012-12-23 22:01 |
| 2012-12-27 13:08 | wmayer | Target Version | => 0.14 |
| 2013-07-02 03:51 | wmayer | Status | acknowledged => assigned |
| 2013-07-02 03:51 | wmayer | Assigned To | => wmayer |
| 2013-07-09 15:03 | wmayer | Note Added: 0003368 | |
| 2013-07-09 15:03 | wmayer | Status | assigned => closed |
| 2013-07-09 15:03 | wmayer | Resolution | open => fixed |
| 2013-07-09 15:03 | wmayer | Fixed in Version | => 0.14 |
