| 0000943 | Draft | Feature | public | 2013-01-06 14:37 | 2013-12-20 21:19 |
| Summary | 0000943: Add more snap behaviours for walls and structs | ||||
| Description | When building walls and structs, additional snap locations and trackers should appear, allowing to place new objects precisely at certain distances from existing walls and structs - add temp dimension trackers - allow to edit those dimensions - track the base points of last hovered wall/struct | ||||
| 2013-01-06 14:37 | yorik | New Issue | |
| 2013-01-06 14:37 | yorik | Status | new => assigned |
| 2013-01-06 14:37 | yorik | Assigned To | => yorik |
| 2013-02-06 12:38 | yorik | Project | Arch => Draft |
| 2013-12-20 21:19 | yorik | Note Added: 0003955 | |
| 2013-12-20 21:19 | yorik | Status | assigned => closed |
| 2013-12-20 21:19 | yorik | Resolution | open => fixed |
| 2013-12-20 21:19 | yorik | Fixed in Version | => 0.14 |
