| 0000948 | FreeCAD | Bug | public | 2013-01-07 20:08 | 2013-07-09 10:38 |
| Reporter | gwillden | Assigned To | wmayer | ||
| Summary | 0000948: Part names are incorrect on import from STEP file | ||||
| Description | I am using version 0.13, revision 1803, Windows 7, 32-bit. This bug is related to bug/issue 0000550. I have a 6663 KB step file that appears to import correctly but the part names do not match the strings in the PRODUCT fields of the file. I attempted to upload the file but it failed since this bug reporting system has a 5MB file limit on attachments. Please advise how to get this step file to you. Also the bounding boxes for the parts appear in the wrong places that are completely separate from the parts. | ||||
Is it possible to compress the file using a ZIP tool? If this file is still to big then simply split the file into several parts and upload them separately. AFAIK the 5MB limit applies only to a single file you want to upload. Btw, the file is it allowed to be viewed by the public? If not we can make this ticket private so that only the developers can see it. |
2013-01-08 11:45
I attached the zipped STEP file (AP214). I also have an AP203 version if needed. There are no restrictions on this STEP file. It was created by some engineering students using Pro-E. |
Have you been able to reproduce the problem on your end? I want to be able to use FreeCAD for a project I working on for DARPA. They are very keen to use open source, plus it would be good publicity for the FreeCAD project. Thank you for your help. |
Loads fine e.g. with CADExchanger. |
git show adc0052 |
| 2013-01-07 20:08 | gwillden | New Issue | |
| 2013-01-08 10:20 | wmayer | Note Added: 0002819 | |
| 2013-01-08 11:45 | gwillden | File Added: Carrier_Body.zip | |
| 2013-01-08 11:53 | gwillden | Note Added: 0002826 | |
| 2013-01-14 21:55 | gwillden | Note Added: 0002851 | |
| 2013-07-02 03:49 | wmayer | Note Added: 0003323 | |
| 2013-07-02 03:49 | wmayer | Assigned To | => wmayer |
| 2013-07-02 03:49 | wmayer | Status | new => confirmed |
| 2013-07-09 10:38 | wmayer | Note Added: 0003363 | |
| 2013-07-09 10:38 | wmayer | Status | confirmed => closed |
| 2013-07-09 10:38 | wmayer | Resolution | open => fixed |
| 2013-07-09 10:38 | wmayer | Fixed in Version | => 0.14 |
