| 0000951 | PartDesign | Bug | public | 2013-01-08 16:29 | 2013-02-21 05:13 |
| Reporter | victim70 | Assigned To | |||
| Summary | 0000951: Pad of second scetch is invisible | ||||
| Description | Pading of scetch is not perform, for second scetch Pad001. The second scetch Scetch001, Pad001 is full constrained with dimension and external constraint to first Pad. | ||||
| Additional Information | Curent GIT version of FreeCad. Gentoo linux. | ||||
2013-01-08 16:29
Additional info for system: Gentoo 32 bit Branch: master Hash:afb335519329a67f8ad5b7d5d906128e77543273 Python version: 2.7.3 Qt version: 4.8.4 SoQt version: 1.5.0-r1 coin version: 3.1.3-r1 opencascade version: 6.5 Second reproducing system: OS: Ubuntu 12.04.1 LTS 32bit |
If you edit Pad001's parameters and check "Reversed', you will see that the Pad succeeds. In the default direction it cannot succeed because you would get a disjointed solid attached to a single edge. This is not allowed by most CAD software. If you really need your second pad to go in the other direction and be joined to the first one by its edge, then you should not map your sketch to the first Pad's face. When mapping a sketch to a face, the system assumes you want to add/remove material to an existing solid; when not mapping the sketch, it assumes you want to create a new solid. Hence, this is not a bug, but working as designed. |
2013-01-12 20:13
Ok Please close issue. |
Closed as by request of reporter |
| 2013-01-08 16:29 | victim70 | New Issue | |
| 2013-01-08 16:29 | victim70 | File Added: router_FCStd_and_picture.zip | |
| 2013-01-08 17:17 | victim70 | Note Added: 0002829 | |
| 2013-01-08 19:10 | victim70 | Note Edited: 0002829 | |
| 2013-01-12 20:11 | normandc | Note Added: 0002842 | |
| 2013-01-12 20:13 | normandc | File Added: freecad_reversedpad.png | |
| 2013-01-13 16:55 | victim70 | Note Added: 0002847 | |
| 2013-02-21 05:13 | jrheinlaender | Note Added: 0002932 | |
| 2013-02-21 05:13 | jrheinlaender | Status | new => closed |
| 2013-02-21 05:13 | jrheinlaender | Resolution | open => no change required |
