| 0000959 | FreeCAD | Bug | public | 2013-01-15 10:04 | 2013-03-23 15:13 |
| Reporter | benjamin12345 | Assigned To | yorik | ||
| Summary | 0000959: arc orientation sometimes becomes wrong when exporting to DXF | ||||
| Description | When drawing arcs with sketcher and then exporting the sketch to DXF, the arc orientation sometimes becomes wrong. I have attached a zip-file with one fcstd-file and one dxf-file that illustrate this problem. I have reported this once before and it was marked as fixed, but apparently it is not. Or maybe it is fixed in another git branch? | ||||
| Additional Information | Freecad version: 0.13 Git revision: 1822 Git branch: master OS: Ubuntu 12.10 64-bit | ||||
2013-01-15 10:04
This is also an issue in Freecad version: 0.12 Revision: 5284 Date: 2011/12/12 21:03:10 OS: Windows 7 (32-bit) I can add another sample if needed. |
I believe this is fixed in 0.13 but I?l check. |
Ok, this is another problem than before, the sketch-draft conversion works fine, but there is something wrong in the DXF export code. |
I did a fix (commit f66c433) that seems to fix the problem in all cases I could test. I'll leave this report open a bit more to see if someone still reports issues... |
Closed because no more feedback. Reopen if needed! |
| 2013-01-15 10:04 | benjamin12345 | New Issue | |
| 2013-01-15 10:04 | benjamin12345 | File Added: arc_bug.zip | |
| 2013-02-11 08:27 | daramarak | Note Added: 0002893 | |
| 2013-02-14 21:05 | yorik | Status | new => assigned |
| 2013-02-14 21:05 | yorik | Assigned To | => yorik |
| 2013-02-14 21:06 | yorik | Note Added: 0002908 | |
| 2013-02-16 21:16 | yorik | Note Added: 0002912 | |
| 2013-02-16 23:36 | yorik | Severity | major => minor |
| 2013-02-21 21:36 | yorik | Note Added: 0002937 | |
| 2013-02-21 21:36 | yorik | Status | assigned => feedback |
| 2013-03-23 15:13 | yorik | Note Added: 0002999 | |
| 2013-03-23 15:13 | yorik | Status | feedback => closed |
| 2013-03-23 15:13 | yorik | Resolution | open => fixed |
| 2013-03-23 15:13 | yorik | Fixed in Version | => 0.14 |
