| 0000969 | FreeCAD | Bug | public | 2013-01-31 17:28 | 2013-07-09 13:02 |
| Reporter | wwojciechowski | Assigned To | wmayer | ||
| Summary | 0000969: FreeCad crash after Edit -> Alignment... | ||||
| Description | I receive Segfault every time I try to aling even simplest parts. Segfault happened at vbo_save_playback_vertex_list () from /usr/lib/i386-linux-gnu/libdricore9.1.0.so.1 OS: Ubuntu 12.10 Platform: 32-bit Version: 0.13.1827 (Git) Branch: master Hash: 372b4542ee4588328c31819a337a656eb276d596 Python version: 2.7.3 Qt version: 4.8.3 Coin version: 3.1.3 SoQt version: 1.5.0 | ||||
| Additional Information | It is replicable also for Ubuntu 12.10 x86_64 I include FreeCAD.crash core file as well as sample "ukladanie-test.fcstd". | ||||
2013-01-31 17:28
2013-01-31 17:30
According to the backtrace this is clearly an issue with the graphic driver. Just search for vbo_save_playback_vertex_list & crash in the web and you'll find many other bug reports for other applications. Since this function is used by Coin3d for display lists for caching OpenGL calls it might work to switch off caching globally. Therefore set the environment variable IV_SEPARATOR_MAX_CACHES=0 and restart FreeCAD. |
I can reproduce the crash. Steps to reproduce: open ukladanie-test.fcstd select both elements frez and oska click edit->align I have a Intel graphics hd 4000 and a nearly stock kernel on 64Bit: uname -a Linux pandora 3.7.5-1-ARCH #1 SMP PREEMPT Mon Jan 28 10:03:32 CET 2013 x86_64 GNU/Linux I'm using xf86-video-intel 2.20.19-1 graphics driver FreeCad Version: FreeCAD 0.13, Libs: 0.13R1827 (Git) Stacktrace in FreeCad2.crash |
2013-02-03 20:16
@wmayer Thank you. Setting Coin3D environment variable worked for me: $ Exec=env IV_SEPARATOR_MAX_CACHES=0 freecad & There is also possible to disable display list caching globaly by setting variable by edit /etc/environment |
Ups. Yes, $ export IV_SEPARATOR_MAX_CACHES=0 ; freecad made it work for me, too. Is it a graphic driver problem, or OpenGL problem, or a Coin3d problem, and could it be fixed within FreeCAD (besides setting the environment variable)? |
We should create a troubleshoot page in the wiki and add this one. |
Added to http://www.freecadweb.org/wiki/index.php?title=FAQ#FreeCAD_crashes_after_Edit_-.3E_Alignment |
| 2013-01-31 17:28 | wwojciechowski | New Issue | |
| 2013-01-31 17:28 | wwojciechowski | File Added: FreeCAD.crash | |
| 2013-01-31 17:30 | wwojciechowski | File Added: ukladanie-test.fcstd | |
| 2013-02-02 09:13 | wmayer | Note Added: 0002875 | |
| 2013-02-03 20:15 | peterinker | Note Added: 0002878 | |
| 2013-02-03 20:15 | peterinker | Note Edited: 0002878 | |
| 2013-02-03 20:16 | peterinker | File Added: FreeCAD2.crash | |
| 2013-02-04 13:52 | wwojciechowski | Note Added: 0002880 | |
| 2013-02-04 13:53 | wwojciechowski | Note Edited: 0002880 | |
| 2013-02-04 21:33 | peterinker | Note Added: 0002882 | |
| 2013-07-01 10:08 | wmayer | Note Added: 0003313 | |
| 2013-07-09 13:01 | wmayer | Status | new => assigned |
| 2013-07-09 13:01 | wmayer | Assigned To | => wmayer |
| 2013-07-09 13:02 | wmayer | Note Added: 0003367 | |
| 2013-07-09 13:02 | wmayer | Status | assigned => closed |
| 2013-07-09 13:02 | wmayer | Resolution | open => no change required |
