| 0000972 | FreeCAD | Bug | public | 2013-02-04 19:02 | 2016-05-15 21:37 |
| Reporter | tanderson69 | Assigned To | wmayer | ||
| Priority | normal | Severity | crash | Reproducibility | have not tried |
| Summary | 0000972: part/offset crash | ||||
| Description | steps to reproduce. 1) open attached file. 2) part workbench. 3) select shell. 4) offset command. 5) check "fill offset" in task view. | ||||
| Tags | OCC Bug | ||||
2013-02-04 19:02
Confirm on FreeCAD 0.13, Libs: 0.13R1827 (Git) on 64Bit Linux Backtrace in OffsetFill.trace |
2013-02-04 21:42
That's a bug in BRepFill_Generator::CreateKPart() (called from Perform). There is this line of code: gp_Circ c1 = (Handle(Geom_Circle)::DownCast(C1))->Circ(); However, for the crash the object behind C1 is Geom_TrimmedCurve and not a Geom_Circle. This should be check with OCC 6.6 and reported to them if it's still wrong. |
Still happens with OCC 6.6! |
Still happens with OCC 6.7! |
I can't reproduce the problem with OCCT 6.8.1-dev (f1b0b4f 2015-02-27) The shape is not always valid for all combination of parameters. But i wasn't able to get a crash. OS: Debian GNU/Linux 7.8 (wheezy) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4625 +342 (Git) Hash: 5f00c31e8c82f81f350c1ac55db0db6f9e9af297 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 4.0.0a OCC version: 6.8.1.dev-f1b0b4f |
Still happens with OCC 6.8.0 alias oce 0.17 |
With the recently released occ 7.0 I can confirm that it works now. |
| 2013-02-04 19:02 | tanderson69 | New Issue | |
| 2013-02-04 19:02 | tanderson69 | File Added: surface.FCStd | |
| 2013-02-04 21:42 | peterinker | Note Added: 0002883 | |
| 2013-02-04 21:42 | peterinker | File Added: OffsetFill.trace | |
| 2013-07-01 15:55 | wmayer | Note Added: 0003321 | |
| 2013-07-01 15:55 | wmayer | Status | new => confirmed |
| 2013-07-02 02:59 | wmayer | Status | confirmed => assigned |
| 2013-07-02 02:59 | wmayer | Assigned To | => wmayer |
| 2013-07-13 14:07 | wmayer | Note Added: 0003402 | |
| 2014-03-02 10:10 | wmayer | Note Added: 0004344 | |
| 2015-03-01 20:34 | shoogen | Note Added: 0005847 | |
| 2015-04-05 15:32 | wmayer | Note Added: 0005967 | |
| 2015-04-08 06:51 | shoogen | Tag Attached: OCC Bug | |
| 2016-05-15 21:37 | wmayer | Note Added: 0007110 | |
| 2016-05-15 21:37 | wmayer | Status | assigned => closed |
| 2016-05-15 21:37 | wmayer | Resolution | open => no change required |
| 2016-05-15 21:37 | wmayer | Fixed in Version | => 0.17 |
