| 0000975 | FreeCAD | Bug | public | 2013-02-05 03:39 | 2013-03-02 21:42 |
| Reporter | jdbrandmeyer | Assigned To | yorik | ||
| Summary | 0000975: DXF Export produces only straight lines | ||||
| Description | Starting from the enclosed file, select a face of the PolarPattern in the x-y plane. 2) File->Export -> Autodesk DXF 3) In FEMM (a third party application) create a new magnetics problem, and import the saved DXF geometry. The geometry shows that all of the curved lines (ARCs) have been turned into straight lines instead. The example DXF file is also attached. | ||||
| Additional Information | Host is Windows 7 64-bit. Application is 32-bit. OS: Windows 7 Platform: 32-bit Version: 0.13.1828 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.3.0 | ||||
2013-02-05 03:39
2013-02-05 03:40
2013-02-05 13:49
I don't see any problem in the dxf file (see attached screenshot)... Maybe the problem lies in your FEMM application? |
From the FEMM manual: FEMM does not understand all the possible tags that can be included in a dxf file; instead, it simply strips out the commands involved with drawing lines, circles, and arcs. All other information is simply ignored. Yes, I see that some other CAD programs will show that the DXF file lines up as intended. |
Okay then I'll close this report, since it seems to me no action is needed from our part, but don't hesitate to reopen if you think this is not the case. |
| 2013-02-05 03:39 | jdbrandmeyer | New Issue | |
| 2013-02-05 03:39 | jdbrandmeyer | File Added: stator.FCStd | |
| 2013-02-05 03:40 | jdbrandmeyer | File Added: quarter_stator.dxf | |
| 2013-02-05 13:49 | yorik | File Added: stator.jpg | |
| 2013-02-05 13:49 | yorik | Note Added: 0002885 | |
| 2013-02-05 13:49 | yorik | Assigned To | => yorik |
| 2013-02-05 13:49 | yorik | Status | new => feedback |
| 2013-03-02 15:17 | jdbrandmeyer | Note Added: 0002954 | |
| 2013-03-02 21:42 | yorik | Note Added: 0002955 | |
| 2013-03-02 21:42 | yorik | Status | feedback => closed |
| 2013-03-02 21:42 | yorik | Resolution | open => no change required |
| 2013-03-02 21:42 | yorik | Fixed in Version | => 0.14 |
