| 0000982 | Arch | Feature | public | 2013-02-06 12:43 | 2013-07-18 14:05 |
| Summary | 0000982: Arch module - Space object | ||||
| Description | A space object, that would define an empty space, and could be made of a solid, or defined by boundary objects (walls, floors, ceilings, etc). It should be able to return a volume, and if applicable a floor area, wall area, ceiling area, and if applicable openings area Question is: how to define a volume by border planes... | ||||
Solutions to calculate the volume: http://forum.freecadweb.org/viewtopic.php?f=10&t=3541 |
2013-02-06 14:16
More ideas - annexed space calculation.jpg |
Basic implementation done with commit b263789 A new space tool allows to create Space objects on top of a selected solid shape, or from several selected boundary faces. The Space object remains bound to the boundary object in case they change. New boundaries can be added later on with the Arch Add tool, even on space objects created from a solid shape. Existing boundaries can be removed from a Space object with the Arch Remove tool. Space objects use the "Detailed" display mode to show the horizontal area (taken from a plane crossing the space at its central point) at the center of the space. |
| 2013-02-06 12:43 | yorik | New Issue | |
| 2013-02-06 12:43 | yorik | Status | new => assigned |
| 2013-02-06 12:43 | yorik | Assigned To | => yorik |
| 2013-02-06 13:46 | yorik | Note Added: 0002887 | |
| 2013-02-06 14:16 | yorik | File Added: space calculation.jpg | |
| 2013-02-06 14:17 | yorik | Note Added: 0002888 | |
| 2013-07-18 14:05 | yorik | Note Added: 0003416 | |
| 2013-07-18 14:05 | yorik | Status | assigned => closed |
| 2013-07-18 14:05 | yorik | Resolution | open => fixed |
| 2013-07-18 14:05 | yorik | Fixed in Version | => 0.14 |
