| 0000984 | FreeCAD | Bug | public | 2013-02-10 19:18 | 2013-02-13 09:05 |
| Reporter | danielfalck | Assigned To | |||
| Summary | 0000984: latest git version doesn't build on mint linux 2013-02-10 | ||||
| Description | I just did a git pull of master and tried to build, but got this error: /home/danfalck/cadcam/freecad/freecad1/src/Base/Uuid.cpp: In member function ‘void Base::Uuid::setValue(const char*)’: /home/danfalck/cadcam/freecad/freecad1/src/Base/Uuid.cpp:79:19: error: ‘runtime_error’ is not a member of ‘std’ make[2]: *** [src/Base/CMakeFiles/FreeCADBase.dir/Uuid.cpp.o] Error 1 make[1]: *** [src/Base/CMakeFiles/FreeCADBase.dir/all] Error 2 make: *** [all] Error 2 | ||||
| Additional Information | git log commit d739a2e41bd4724b76db9946124356b9771c9283 Author: jriegel <FreeCAD@juergen-riegel.net> Date: Sun Feb 10 20:02:21 2013 +0100 Add all base system changes from the Assembly branch I am running Linux Mint Maya (Ubuntu variant) and had been building successfully earlier in the week. | ||||
I am using gcc 4.6.3 and libboost 1.46 |
Hm looking at the git logs, Jürgen has started the big Assembly move. There might be more building problems during some time, until it is done and settled... |
I tested today, still failing on Linux Mint Maya (14). If you want to fix it, simply add #include <stdexcept> On top of src/Base/Uuid.cpp file But more errors can be expected later... src/Main/MainPy.cpp (line 131): - uuid.UuidStr=""; + uuid.setValue(""); |
git show 8160c8280f24fc8f25f5975bbda1c6d8a22291ae |
| 2013-02-10 19:18 | danielfalck | New Issue | |
| 2013-02-10 19:22 | danielfalck | Note Added: 0002891 | |
| 2013-02-10 22:09 | yorik | Note Added: 0002892 | |
| 2013-02-12 14:43 |
Note Added: 0002896 | |
| 2013-02-12 14:44 |
Note Edited: 0002896 | |
| 2013-02-12 14:48 |
| 2013-02-13 09:05 | wmayer | Note Added: 0002901 | |
| 2013-02-13 09:05 | wmayer | Status | new => closed |
| 2013-02-13 09:05 | wmayer | Resolution | open => fixed |
| 2013-02-13 09:05 | wmayer | Fixed in Version | => 0.14 |
