| 0000985 | FreeCAD | Bug | public | 2013-02-11 06:34 | 2013-02-13 09:11 |
| Reporter | bergerc | Assigned To | |||
| Summary | 0000985: [MAC OS X] compilation error "'PI' was not declared in this scope" (svn version) | ||||
| Description | Hi, I have the following error when I compile FreeCAD SVN version (At revision 5443.) ././src/SMESH/SMESH_MeshEditor.cpp:1377:20: error: 'PI' was not declared in this scope I join my config.log file, I don't know if it's related to my environment, I use mac ports versions of the dependencies, except for SoQt-1.5.0, LibOpenCASCADE (OCE git version). I use gcc mac ports version gcc mp-gcc46 Thanks for your help, Christophe | ||||
| Additional Information | libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../../.. -I/usr/local/include/oce/ -I././inc/ -I/opt/local/Library/Frameworks/Python.framework/Versions/2.6/include/python2.6 -I/opt/local/include -I/opt/local/include -D_OCC64 -O2 -DNDEBUG -D_REENTRANT -Wall -Wno-sign-compare -Wno-switch -Wno-reorder -Wno-unused -Wno-parentheses -Wno-comment -g -O2 -Wno-deprecated -frtti -MT SMESH_MeshEditor.lo -MD -MP -MF .deps/SMESH_MeshEditor.Tpo -c ././src/SMESH/SMESH_MeshEditor.cpp -fno-common -DPIC -o .libs/SMESH_MeshEditor.o ././src/SMESH/SMESH_MeshEditor.cpp: In function 'double getAngle(const SMDS_MeshElement*, const SMDS_MeshElement*, const SMDS_MeshNode*, const SMDS_MeshNode*)': ././src/SMESH/SMESH_MeshEditor.cpp:1377:20: error: 'PI' was not declared in this scope make[4]: *** [SMESH_MeshEditor.lo] Error 1 make[3]: *** [all-recursive] Error 1 make[2]: *** [all-recursive] Error 1 make[1]: *** [all-recursive] Error 1 make: *** [all] Error 2 | ||||
2013-02-11 06:34
The svn repo is deprecated in favor of git. The repo you're trying to compile is more than a year old. I wonder why you used the svn, I thought we deleted all mention of it in the wiki. |
Thanks i'll get the git repo sources. The page "https://sourceforge.net/apps/mediawiki/free-cad/index.php?title=CompileOnMac" is not up to date. Having regards to the new package (0.13.1830) only the pre-requisites are still valid. In the Mac ports version, some details lacks : port -v install Coin Manual install of SoQt-1.5.0.tar.gz (https://bitbucket.org/Coin3D/coin/downloads/SoQt-1.5.0.tar.gz) Manual install of LibOpenCASCADE (https://github.com/tpaviot/oce.git) Selection of the last version of the gcc compiler: port -v install gcc_select port select --list gcc select the last version : port select --set gcc mp-gcc46 Ticket can be closed. |
Thanks i'll get the git repo sources. The page "https://sourceforge.net/apps/mediawiki/free-cad/index.php?title=CompileOnMac" is not up to date. Having regards to the new package (0.13.1830) only the pre-requisites are still valid. In the Mac ports version, some details lacks : port -v install Coin Manual install of SoQt-1.5.0.tar.gz (https://bitbucket.org/Coin3D/coin/downloads/SoQt-1.5.0.tar.gz) Manual install of LibOpenCASCADE (https://github.com/tpaviot/oce.git) Selection of the last version of the gcc compiler: port -v install gcc_select port select --list gcc select the last version : port select --set gcc mp-gcc46 Thank you, Ticket can be closed. |
Thanks for bringing the outdated wiki page to our attention. I'll at least change the info about the repository, but as for the rest I would feel more comfortable if someone who did compile on Mac updated the page. BTW this forum topic may be useful for info on compiling on Mac: http://forum.freecadweb.org/viewtopic.php?f=4&t=2064 |
documentation has been updated |
| 2013-02-11 06:34 | bergerc | New Issue | |
| 2013-02-11 06:34 | bergerc | File Added: config.log | |
| 2013-02-12 11:53 | normandc | Note Added: 0002895 | |
| 2013-02-12 18:21 | bergerc | Note Added: 0002897 | |
| 2013-02-12 18:21 | bergerc | Note Added: 0002898 | |
| 2013-02-12 22:24 | normandc | Note Added: 0002900 | |
| 2013-02-13 09:11 | wmayer | Note Added: 0002902 | |
| 2013-02-13 09:11 | wmayer | Status | new => closed |
| 2013-02-13 09:11 | wmayer | Resolution | open => no change required |
| 2013-02-13 09:11 | wmayer | Fixed in Version | => 0.14 |
