| 0000988 | PartDesign | Bug | public | 2013-02-14 13:11 | 2014-12-26 18:41 |
| Reporter | logari81 | Assigned To | jrheinlaender | ||
| Summary | 0000988: Groove fails to create a valid solid | ||||
| Description | The groove in the attached file fails to create a valid solid. | ||||
2013-02-14 13:11
I wonder if it's because the sketch is mapped to a primitive Box. I just reproduced this example with a padded rectangle and it works. |
it actually has to do with the placement of the box. For some angles the groove succeeds, for other angles it fails. |
Its a problem of the sketch shape being coincident with the face of the box being sketched on. If I move the sketch shape just by 2*Precision::Confusion() vertical to the face, everything is fine (except for a performance penalty which doesn't occur if I move by 1 unit instead of Precision::Confusion()) But IMHO its not an option to move the sketch shape. It is not the user's intent and might give unexpected geometry (especially if moving by a whole unit). Interestingly, the problem also occurs even with the symmetric option, when the sketch shape is rotated away from the face of the box! |
This problem is solved after moving PropertyFloat to double precision |
| 2013-02-14 13:11 | logari81 | New Issue | |
| 2013-02-14 13:11 | logari81 | File Added: groove-failed.fcstd | |
| 2013-02-15 09:17 | jrheinlaender | Status | new => assigned |
| 2013-02-15 09:17 | jrheinlaender | Assigned To | => jrheinlaender |
| 2013-02-17 16:49 | normandc | Note Added: 0002916 | |
| 2013-02-17 17:05 | logari81 | Note Added: 0002917 | |
| 2013-02-20 15:27 | jrheinlaender | Note Added: 0002925 | |
| 2013-03-26 14:46 | jrheinlaender | Note Added: 0003009 | |
| 2014-12-26 18:41 | normandc | Status | assigned => closed |
| 2014-12-26 18:41 | normandc | Resolution | open => fixed |
| 2014-12-26 18:41 | normandc | Fixed in Version | => 0.14 |
