| 0000099 | FreeCAD | Bug | public | 2010-05-21 14:57 | 2011-01-06 21:46 |
| Target Version | 0.11 | ||||
| Summary | 0000099: Upgrading of FreeCAD doesn't work | ||||
| Description | When version FreeCAD_0.10.3133_x86_unstable_setup.msi is installed and you try to upgrade to version FreeCAD_0.10.3142_x86_unstable_setup.msi then a message comes up: Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel. This was tested on Windows 7 64-bit edition. | ||||
Thats normal behaviour of the Wix installer - you have to start msi.exe with a certain option to get a automatic upgrade. I dont know a trick to do a automatic update with Wix.... |
Its a known problem to the Wix installer, dont know a workaraound.... |
| 2010-05-21 14:57 | wmayer | New Issue | |
| 2010-05-21 14:57 | wmayer | Status | new => assigned |
| 2010-05-21 14:57 | wmayer | Assigned To | => Jriegel |
| 2010-05-27 12:01 |
Note Added: 0000225 | |
| 2010-06-29 13:33 |
Target Version | 0.10 => 0.11 |
| 2011-01-06 21:46 |
Note Added: 0000489 | |
| 2011-01-06 21:46 |
Status | assigned => closed |
| 2011-01-06 21:46 |
Resolution | open => not fixable |
