| 0001040 | FreeCAD | Feature | public | 2013-03-01 11:57 | 2018-08-26 15:22 |
| Reporter | crashfridh | Assigned To | |||
| Summary | 0001040: Add new list properties which include column names | ||||
| Description | In ticket 0001038 it was suggested to improve the view of the dialog for list properties by adding a column with indices. I would also like to suggest new list types which, besides showing String, Float or Integer, would also show custom column names. These would be very useful for showing for instance spectral values. A possible implementation would take as argument a list with tuples, where the first value of the tuple is a string representing the column name, and the second value a bool, string, float or int, depending on which type of list is chosen. It can be discussed whether these are new types of Property*List, or whether the current Property*Lists should be changed. So whether they should try and show column names if a list with tuples of size 2 are given as argument. Another topic of discussion could be that, if lists of tuples are used and a table as representation, the list might as well contain larger tuples, as long as all of them are same size. See discussion in https://forum.freecadweb.org/viewtopic.php?f=8&t=3666 | ||||
@normandc when you get a moment, do you mind weighing in on this ticket? |
Sorry this is way too technical to me. I don't understand this feature request. "Tuples" may as well be Mandarin to me. |
Reminder sent to: berndhahnebach In the forum thread there was a reference to FEM. Do you mind taking a look at this ticket and offer your opinion? Thanks! |
@berndhahnebach ping |
Instead of a very special property type you can also use a spreadsheet now. |
| 2013-03-01 11:57 | crashfridh | New Issue | |
| 2017-02-20 00:42 | Kunda1 | Description Updated | |
| 2017-02-20 00:43 | Kunda1 | Relationship added | related to 0001038 |
| 2017-02-20 00:44 | Kunda1 | Note Added: 0008378 | |
| 2017-02-20 00:44 | Kunda1 | Tag Attached: #pending | |
| 2017-02-20 00:49 | normandc | Note Added: 0008379 | |
| 2017-03-10 02:17 | Kunda1 | Note Added: 0008603 | |
| 2017-08-28 14:35 | Kunda1 | Note Added: 0010022 | |
| 2017-10-18 13:03 | wmayer | Status | new => closed |
| 2017-10-18 13:03 | wmayer | Resolution | open => no change required |
| 2017-10-18 13:03 | wmayer | Note Added: 0010318 | |
| 2018-08-26 15:22 | Kunda1 | Tag Detached: #pending |
