| 0001105 | Sketcher | Feature | public | 2013-04-21 15:43 | 2013-07-14 14:14 |
| Reporter | detlet | Assigned To | wmayer | ||
| Summary | 0001105: disable grid in sketcher | ||||
| Description | If you disable the grid in sketcher in the side pane this state should at least be saved. For now, if you disable the grid, every time you reopen a sketch the grid is be enabled again. Also nice would be a global configuration option, to disable the grid, cause often the grid makes the sketch hard to read. | ||||
| 2013-04-21 15:43 | detlet | New Issue | |
| 2013-04-22 20:00 | yorik | Relationship added | child of 0001049 |
| 2013-07-14 14:14 | wmayer | Status | new => assigned |
| 2013-07-14 14:14 | wmayer | Assigned To | => wmayer |
| 2013-07-14 14:14 | wmayer | Note Added: 0003408 | |
| 2013-07-14 14:14 | wmayer | Status | assigned => closed |
| 2013-07-14 14:14 | wmayer | Resolution | open => fixed |
| 2013-07-14 14:14 | wmayer | Fixed in Version | => 0.14 |
