| 0001107 | FreeCAD | Feature | public | 2013-04-24 23:43 | 2014-03-09 09:46 |
| Reporter | lingomaniac88 | Assigned To | wmayer | ||
| Summary | 0001107: Ability to specify more decimal places of precision for fillets, etc. | ||||
| Description | I noticed that when trying to perform a fillet on an edge, I could only specify the radius to two decimal places. Specifically, I was trying to do an 1/8" radius (3.175mm) fillet, and I could only enter 3.17 into the box. Here are the steps I used to reproduce this issue: 1. In Draft mode, draw a square with side length 2.5" (63.5mm). 2. In Part Design mode, extrude it 1.5" (38.1mm). 3. Select the four vertical lines aligned with the Z-axis (in this case, the 1.5" long ones) and click the Fillet button. 4. Try to enter "3.175" for the radius in the toolbar where it reads Fillet Parameters. It will only register 3.17. | ||||
FreeCAD: master fb994e20 2014-02-16 18:02:09 Details Diff |
+ fixes 0000854: Ability to change number of digits to the right of decimal place in spinboxes |
Affected Issues 0000854, 0001107 |
| mod - src/Gui/InputVector.cpp | Diff File | ||
| mod - src/Gui/Placement.cpp | Diff File | ||
| mod - src/Mod/Inspection/Gui/VisualInspection.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgRegularSolidImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/CrossSections.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgExtrusion.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgFilletEdges.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartCylinderImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPrimitives.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/Mirroring.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskOffset.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskChamferParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskDraftParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskFilletParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskGrooveParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskHoleParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskLinearPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPocketParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPolarPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskRevolutionParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskScaledParameters.cpp | Diff File | ||
| 2013-04-24 23:43 | lingomaniac88 | New Issue | |
| 2014-03-09 09:45 | wmayer | Changeset attached | => FreeCAD Master master fb994e20 |
| 2014-03-09 09:45 | wmayer | Status | new => closed |
| 2014-03-09 09:45 | wmayer | Assigned To | => wmayer |
| 2014-03-09 09:45 | wmayer | Resolution | open => fixed |
| 2014-03-09 09:45 | wmayer | Fixed in Version | => 0.14 |
| 2014-03-09 09:46 | wmayer | Relationship added | related to 0000854 |
