| 0000854 | FreeCAD | Feature | public | 2012-10-07 17:03 | 2014-03-09 09:46 |
| Reporter | danielfalck | Assigned To | wmayer | ||
| Summary | 0000854: Ability to change number of digits to the right of decimal place in spinboxes | ||||
| Description | It would be good to be able to have more than two digits to the right of the decimal in some cases for placement, size, etc, in the spinboxes that are in the Property, Data tabs. Having .01 as the smallest value possible with a spinbox sometimes isn't going to work for some things. I usually work around this by using python scripting, but I think a lot of engineers might not want to do this. If this is a lot of work, let me know. I should be able to help with this, if I can figure out where to start. I grepped the source and there seem to be thousands of references to "PrefDoubleSpinBox" , so I'm a bit intimidated. Thanks, Dan | ||||
For double spin boxes of the property editor we already have a solution. There we use the number of decimals of the units API framework. At the moment you can set the default value in the parameter editor under BaseApp/Preferences/Units/Decimals. For all other double spin boxes used in dialogs it is not that easy. Here we have to explicitly add a line for each occurrence of a double spin box and set its number of decimals: spinBox->setDecimals(Base::UnitsApi::getDecimals()); Or instead of doing this for every single spin box which is a bit tedious we can do that in the command class or in the dialog class: QList<QDoubleSpinBox*> list = dialog->findChildren<QDoubleSpinBox*>(); for (QList<QDoubleSpinBox*>::iterator it = list.begin(); it != list.end(); ++it) (*it)->setDecimals(Base::UnitsApi::getDecimals()); |
Thanks. I have this version running on this machine at the moment: OS: Ubuntu 10.04.4 LTS Platform: 64-bit Version: 0.13.1512 (Git) Branch: master Hash: e11e4ba9ff7caaff018c27c1690926041ff94c5e Python version: 2.6.5 Qt version: 4.7.0 Coin version: 3.1.2 SoQt version: 1.4.2a OCC version: 6.5.0 Under 'Tools' 'Edit Parameters' 'BaseApp/Preferences/Units/' the screen has nothing to edit- it's blank |
You have to manually add the new parameter "Decimals" (type is int) and set the number of decimals you want. Then restart FreeCAD. |
Couldn't the Decimals parameter be created automatically at FreeCAD install so the end user doesn't have to? |
I just adapted the Draft and Arch modules to use this setting too |
FreeCAD: master fb994e20 2014-02-16 18:02:09 Details Diff |
+ fixes 0000854: Ability to change number of digits to the right of decimal place in spinboxes |
Affected Issues 0000854, 0001107 |
| mod - src/Gui/InputVector.cpp | Diff File | ||
| mod - src/Gui/Placement.cpp | Diff File | ||
| mod - src/Mod/Inspection/Gui/VisualInspection.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgRegularSolidImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/CrossSections.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgExtrusion.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgFilletEdges.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartCylinderImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPrimitives.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/Mirroring.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskOffset.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskChamferParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskDraftParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskFilletParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskGrooveParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskHoleParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskLinearPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPocketParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPolarPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskRevolutionParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskScaledParameters.cpp | Diff File | ||
| 2012-10-07 17:03 | danielfalck | New Issue | |
| 2012-10-08 12:58 | wmayer | Note Added: 0002444 | |
| 2012-10-09 23:51 | danielfalck | Note Added: 0002449 | |
| 2012-10-10 07:12 | wmayer | Note Added: 0002450 | |
| 2013-06-29 15:40 | wmayer | Status | new => assigned |
| 2013-06-29 15:40 | wmayer | Assigned To | => wmayer |
| 2013-06-29 16:08 | normandc | Note Added: 0003299 | |
| 2013-09-29 14:22 | yorik | Note Added: 0003700 | |
| 2014-02-16 17:30 | wmayer | Changeset attached | => FreeCAD Master master fb994e20 |
| 2014-02-16 17:30 | wmayer | Status | assigned => closed |
| 2014-02-16 17:30 | wmayer | Resolution | open => fixed |
| 2014-02-16 17:50 | wmayer | Relationship added | related to 0001178 |
| 2014-03-09 09:46 | wmayer | Relationship added | related to 0001107 |
