| 0001156 | File formats | Feature | public | 2013-06-22 16:46 | 2021-02-06 06:31 |
| Reporter | templatearray | Assigned To | |||
| Summary | 0001156: JT File Format | ||||
| Description | Specification of the JT file format 8.1 | ||||
| Tags | file format | ||||
2013-06-23 05:09
2013-06-23 05:12
2013-06-23 05:13
2013-06-23 05:15
2013-06-23 05:25
2013-06-23 05:27
2013-06-23 05:28
2013-06-23 05:36
2013-06-23 06:35
2013-06-23 06:36
2013-06-23 06:36
2013-06-23 06:39
2013-06-23 06:43
2013-06-23 06:52
There is already a JT import module in FreeCAD. but it need the JtOpenLib to work which is proprietary.... I don't think jt is implementable in OpenSource... |
Anyone think we should do that? I think we should not.... |
Why does it matter so much, anyway? Is JT commonly used? Supporting interchange of proprietary file formats from a company which has a stake in their use (Siemens) is generally a bad practice, and if you have a bunch of files in this format, you can just use some other CAD (OnShape, for instance - no download, free account, and runs on any OS) to convert them to STEP. EDIT: GrabCAD should also work as an online service to convert from proprietary file types. |
Oh, I just realized I bumped this from 3 years ago... sorry. I saw it in the "Unassigned" list and didn't check the date. |
@yorik do you mind weighing in on this? |
It is very unlikely to be implemented, but we can also just leave the ticket open, someone might get interested in working on this in the future... |
This ticket has been migrated to GitHub as issue 5565. |
| 2013-06-22 16:46 | templatearray | New Issue | |
| 2013-06-22 17:42 | shoogen | Tag Attached: file format | |
| 2013-06-23 05:09 | templatearray | File Added: PLM_Solutions_a.pdf | |
| 2013-06-23 05:12 | templatearray | File Added: PLM_Solutions_b.pdf | |
| 2013-06-23 05:13 | templatearray | File Added: PLM_Solutions_c.pdf | |
| 2013-06-23 05:15 | templatearray | File Added: PLM_Solutions_d.pdf | |
| 2013-06-23 05:25 | templatearray | File Added: JT_File_Format_81_a.pdf | |
| 2013-06-23 05:27 | templatearray | File Added: JT_File_Format_81_b.pdf | |
| 2013-06-23 05:28 | templatearray | File Added: JT_File_Format_81_c.pdf | |
| 2013-06-23 05:36 | templatearray | File Added: JT_File_Format_81_d.pdf | |
| 2013-06-23 06:35 | templatearray | File Added: Jt2Go_Example_1.jt | |
| 2013-06-23 06:36 | templatearray | File Added: Jt2Go_Example_1.brep | |
| 2013-06-23 06:36 | templatearray | File Added: Jt2Go_Example_1.step | |
| 2013-06-23 06:39 | templatearray | File Added: Jt2Go_Example_2.jt | |
| 2013-06-23 06:43 | templatearray | File Added: Jt2Go_Example_2.step | |
| 2013-06-23 06:52 | templatearray | File Added: Jt2Go_Example_2.iges | |
| 2013-06-26 09:08 |
Note Added: 0003239 | |
| 2013-06-26 09:12 |
Note Added: 0003241 | |
| 2013-06-26 09:12 |
Status | new => feedback |
| 2014-08-02 19:26 | shoogen | Project | FreeCAD => File formats |
| 2015-09-09 22:02 | savio araujo | Issue cloned: 0002254 | |
| 2015-09-10 19:18 | yorik | Relationship added | has duplicate 0002254 |
| 2016-06-15 03:27 | lukasubo | Note Added: 0007147 | |
| 2016-06-15 03:29 | lukasubo | Note Added: 0007148 | |
| 2016-06-15 03:45 | lukasubo | Note Edited: 0007147 | |
| 2017-03-02 12:07 | Kunda1 | Note Added: 0008507 | |
| 2017-03-02 13:16 | yorik | Note Added: 0008514 | |
| 2019-07-11 10:23 | tomplatz | File Added: 124.pdf | |
