| 0001166 | Arch | Feature | public | 2013-07-05 22:21 | 2013-12-22 19:21 |
| Summary | 0001166: Arch Railing | ||||
| Description | A railing is an object that can span on a certain length (or follow a baseline), and can be made of several types of subcomponents: - extruded pieces that follow the baseline - placed pieces that are repeated at certain fixed intervals - placed pieces that are repeated a certain number of times over the length of the baseline The typical example is the railing of a balcony, which has horizontal bars that span all the border of the balcony, vertical bars placed every 10cm, and stronger vertical bars at each corner of the balcony Needs to define a good system to define and organize these subcomponents. | ||||
This will be reformatted as a generic frame object, capable of catering all the frame-based objects found in a building, such as: - railings - frame walls - roof framing - etc... It will be based on a sketch or any other 2D object (so one can take advantage for example of the Draft Array, to make parametric frames) and on a profile. Each wire of the base sketch will serve as a guid to extrude the profile, resulting in a complete frame, like the rebar object. |
FreeCAD: master 90a80da1 2013-12-22 20:18:11 Details Diff |
Arch: Frame object - fixes 0001166, 0001314 |
Affected Issues 0001166, 0001314 |
| mod - src/Mod/Arch/Arch.py | Diff File | ||
| add - src/Mod/Arch/ArchFrame.py | Diff File | ||
| mod - src/Mod/Arch/ArchRebar.py | Diff File | ||
| mod - src/Mod/Arch/Arch_rc.py | Diff File | ||
| mod - src/Mod/Arch/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Arch/Resources/Arch.qrc | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Frame.svg | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Frame_Tree.svg | Diff File | ||
| mod - src/WindowsInstaller/ModArch.wxi | Diff File | ||
| 2013-07-05 22:21 | yorik | New Issue | |
| 2013-07-05 22:21 | yorik | Status | new => assigned |
| 2013-07-05 22:21 | yorik | Assigned To | => yorik |
| 2013-07-05 22:28 | yorik | Project | FreeCAD => Arch |
| 2013-12-22 13:45 | yorik | Relationship added | parent of 0001314 |
| 2013-12-22 13:50 | yorik | Note Added: 0003963 | |
| 2013-12-22 19:21 | yorik | Changeset attached | => FreeCAD Master master 90a80da1 |
| 2013-12-22 19:21 | yorik | Status | assigned => closed |
| 2013-12-22 19:21 | yorik | Resolution | open => fixed |
