| 0001314 | Arch | Feature | public | 2013-11-20 19:35 | 2013-12-22 19:21 |
| Summary | 0001314: Arch: Frame walls | ||||
| Description | Add the possibility to make frame walls See discussion at http://forum.freecadweb.org/viewtopic.php?f=23&t=4713 | ||||
Basic ideas: - Walls have a new "Framing" DisplayMode that can show the framing if existing. - Walls have a new "Framing" property that can hold as many frame elements as needed - Some of these elements can be standalone (defined by their own size) - Some of these elements can have one dimension or their position defined by the host wall - Some of these elements can be repeated to fill a certain distance. Need to find an easy way to organize all this. Maybe a sketch, based on the wall? |
Will be merged with railing/frame object |
FreeCAD: master 90a80da1 2013-12-22 20:18:11 Details Diff |
Arch: Frame object - fixes 0001166, 0001314 |
Affected Issues 0001166, 0001314 |
| mod - src/Mod/Arch/Arch.py | Diff File | ||
| add - src/Mod/Arch/ArchFrame.py | Diff File | ||
| mod - src/Mod/Arch/ArchRebar.py | Diff File | ||
| mod - src/Mod/Arch/Arch_rc.py | Diff File | ||
| mod - src/Mod/Arch/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Arch/Resources/Arch.qrc | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Frame.svg | Diff File | ||
| add - src/Mod/Arch/Resources/icons/Arch_Frame_Tree.svg | Diff File | ||
| mod - src/WindowsInstaller/ModArch.wxi | Diff File | ||
| 2013-11-20 19:35 | yorik | New Issue | |
| 2013-11-20 19:35 | yorik | Status | new => assigned |
| 2013-11-20 19:35 | yorik | Assigned To | => yorik |
| 2013-11-20 19:35 | yorik | File Added: wall-studs-framing.jpg | |
| 2013-11-20 19:43 | yorik | Note Added: 0003897 | |
| 2013-12-21 21:56 | yorik | Project | FreeCAD => Arch |
| 2013-12-22 13:45 | yorik | Relationship added | child of 0001166 |
| 2013-12-22 13:46 | yorik | Note Added: 0003962 | |
| 2013-12-22 19:21 | yorik | Changeset attached | => FreeCAD Master master 90a80da1 |
| 2013-12-22 19:21 | yorik | Status | assigned => closed |
| 2013-12-22 19:21 | yorik | Resolution | open => fixed |
