| 0001210 | FreeCAD | Bug | public | 2013-08-12 06:53 | 2014-02-26 15:03 |
| Reporter | vdhproducts | Assigned To | |||
| Summary | 0001210: DLL load failed | ||||
| Description | Whem I installed FreeCAD_0.14.2370_x86_RC_setup.msi I can't open the workbench "COMPLETE" or any other workbench. The error message is "DLL load failed". FreeCAD_0.13.1828_x86_setup.msi works well on same system. | ||||
| Additional Information | Using FreeCAD_0.14.2370_x86_RC_setup.msi setup. Running on Windows XP SP3 | ||||
Start v0.13 and check your macro path. Which directory does it point to? |
C:/Program Files/FreeCAD0.13/Macro |
And you cannot even load the Mesh workbench? |
Yes, I can load the arch, draft,image, mesh design, points and ship. When I try to make a line in the draft Workbench. It gives the following error: Running the Python command 'Draft Line' failed. The rest of the workbenches give the error "DLL load failed" when I try to open them. |
2013-08-13 12:33
In version FreeCAD_0.14.2192_x86_setup.msi there is another error message. Dynamic module not initialized properly. On another windows 7 system freecad 0.14 is working just fine. On my windows XP SP3 system there seems to be a problem. |
Very likely a certain DLL is missing to load the OpenCascade DLLs. Therefore you should use the tool dependency walker (www.dependencywalker.com). In the installation directory copy e.g. Part.pyd into the bin directory (where you see all the TK*.dll files). Drag and drop (the copied) Part.pyd to the dependency walker. On the left side check the dependencies for a missing file. |
According to the dependencywalker the following dll's are missing.(see attachment) WER.dll (missing on system) IESHIMS.dll (missing on system) MSVCR90.dll (this one is present) In which directories is freecad searching for these files, so I can install the dll files there? |
2013-08-14 04:53
After I installed the wer.dll, IESHIMS.dll and MSVR90.dll dependencywalker want more(see missing dll2.png and missing dll3.png) There is no end. What can I do? Or is it just not possible to run freecad 0.14 on a windows XP SP3 system? |
2013-08-14 06:56
2013-08-14 07:02
Unfortunately, the dependency walker gives a couple of false positive like the WER.dll or IESHIMS.dll which can be ignored. Can you maybe upload a screen shot of the tree view? Another point that should be taken into consideration: For version 0.14 a newer OpenCascade version is used compared to 0.13. These two OpenCascade versions are binary incompatible to each other and if for any reason a DLL of one version finds a DLL of the other version it depends on in the system path it won't load. From time to time I have seen Windows systems where application libraries have been copied to C:\Windows\system or C:\Windows\system32. In such a case any application that needs a different version won't work any more because it always searches in these two paths before looking into the PATH environment variable (which can be customized by an application). This is how Windows works and there is no way to change the search order. So, the only fix is to remove application libraries from C:\Windows\system or C:\Windows\system32 because as the name says they are reserved for system libraries only. In your case check if you can find any TK*.dll in one of the above directories and remove them. |
2013-08-14 07:27
2013-08-14 07:27
I removed all the dll's that I'd installed this morning. In the attechment(see png's) you can see the tree view of the three missing dll's. There are no TK*.dll files in the system/system32 directories. Any suggestions? |
Another thing you can try out: In the sub-directories of Mod you will find files with the extension .pyd. Move all of them (unless that of PartDesign) to the bin directory. |
"On another windows 7 system freecad 0.14 is working just fine." I have the same message om my Windows 7 x64 when I'm trying to open any step file. The program starts and can open .FCStd files, but can not export them into .step file neither open step file. The program is FreeCAD_0.14.2370_x86_RC_setup.msi |
After moving all the .pyd files (except for partdesign.pyd), Freecad 0.14 started. Unfortunately I can't open/import any step files. The following error(report view) appears when importing a step file: Traceback (most recent call last): File "<string>", line 1, in <module> <type 'exceptions.ImportError'>: DLL load failed: Kan opgegeven module niet vinden. Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> |
Now I installed the previous version FreeCAD_0.14.2192_x86_setup.msi. In this version the open/import is working when I moved the pyd files to the bin directory. Something is different between the 2192 and the 2370_RC build. |
I installed WinXP + SP3 + vc_redist (9.0.21022.8) as virtual system. For me FreeCAD_0.13.1828_x86_setup.msi and FreeCAD_0.14.2370_x86_RC_setup.msi are both working on this system. For 0.14.2370 I cannot load the FEM module due to a missing DLL but everything else works. So, IMO it's not the installer but something on your system is wrong. |
In my new system with windows 8(HP 3.2GHz cpu, 8GB memory, 64 bits), I installed FreeCAD_0.14.2192_x86_setup. This works just fine. Even importing and opening STEP files. FreeCAD_0.14.2370_x86_RC_setup.msi is still giving the dll load error, when importing or opening STEP models. Same as note above from cctalk (003551) This is a new clean system. Even when moving the .pyd (except partdesign.pyd) files to the bin directory there is no difference. |
Do you have installed vc_redist (version 9.0.21022.8 or later)? |
Ah, wait! In your initial post you said "I can't open the workbench "COMPLETE" or any other workbench." Is this still true that you cannot load them? I have overlooked what cctalk was writing: "The program starts and can open .FCStd files, but can not export them into .step file neither open step file." Yes, I can confirm this too now. The file Import.pyd is missing! |
No, that's no problem anymore with the new system. Is it possible to sent me the import.pyd? Or a new build (maybe including the text string to shape feature(not compiled in this version))? |
2013-09-23 07:43
Copy the file to Mod\Import. |
It is working! Thank you for helping me out. |
It's working now. |
| 2013-08-12 06:53 | vdhproducts | New Issue | |
| 2013-08-12 10:47 | wmayer | Note Added: 0003450 | |
| 2013-08-12 11:00 | vdhproducts | Note Added: 0003451 | |
| 2013-08-13 11:16 | wmayer | Note Added: 0003456 | |
| 2013-08-13 11:45 | vdhproducts | Note Added: 0003457 | |
| 2013-08-13 12:33 | vdhproducts | File Added: Dynamic module not intialized properly.PNG | |
| 2013-08-13 12:35 | vdhproducts | Note Added: 0003458 | |
| 2013-08-13 16:21 | wmayer | Note Added: 0003460 | |
| 2013-08-14 04:53 | vdhproducts | Note Added: 0003462 | |
| 2013-08-14 04:53 | vdhproducts | File Added: Missing DLLs.PNG | |
| 2013-08-14 06:55 | vdhproducts | Note Added: 0003464 | |
| 2013-08-14 06:56 | vdhproducts | File Added: Missing dll 2.PNG | |
| 2013-08-14 07:02 | vdhproducts | File Added: Missingdll3.PNG | |
| 2013-08-14 07:09 | wmayer | Note Added: 0003465 | |
| 2013-08-14 07:27 | vdhproducts | File Added: Tree ieshimsdll and werdll.PNG | |
| 2013-08-14 07:27 | vdhproducts | File Added: Tree MSVCR90dll.PNG | |
| 2013-08-14 07:30 | vdhproducts | Note Added: 0003466 | |
| 2013-09-03 13:11 | wmayer | Note Added: 0003543 | |
| 2013-09-04 17:38 | cctalk | Note Added: 0003551 | |
| 2013-09-04 17:39 | cctalk | Note Edited: 0003551 | |
| 2013-09-05 05:07 | vdhproducts | Note Added: 0003552 | |
| 2013-09-05 05:24 | vdhproducts | Note Added: 0003553 | |
| 2013-09-21 17:29 | wmayer | Note Added: 0003614 | |
| 2013-09-23 05:07 | vdhproducts | Note Added: 0003625 | |
| 2013-09-23 05:41 | wmayer | Note Added: 0003627 | |
| 2013-09-23 06:00 | wmayer | Note Added: 0003628 | |
| 2013-09-23 06:57 | vdhproducts | Note Added: 0003630 | |
| 2013-09-23 07:43 | wmayer | File Added: Import.pyd | |
| 2013-09-23 07:45 | wmayer | Note Added: 0003632 | |
| 2013-09-23 07:53 | vdhproducts | Note Added: 0003633 | |
| 2013-09-24 10:59 | wmayer | Note Added: 0003645 | |
| 2013-09-24 10:59 | wmayer | Status | new => closed |
| 2013-09-24 10:59 | wmayer | Resolution | open => fixed |
| 2013-09-24 10:59 | wmayer | Fixed in Version | => 0.14 |
| 2014-02-26 15:03 | wmayer | Relationship added | has duplicate 0001446 |
