| 0001446 | FreeCAD | Bug | public | 2014-02-26 10:31 | 2014-03-15 13:15 |
| Reporter | rolbit | Assigned To | wmayer | ||
| Platform | Windows | OS | Windows server | OS Version | 2008 r2 |
| Summary | 0001446: STEP export fails under Windows | ||||
| Description | Export from GUI to STEP fails under windows, there is no file generated. If I look at the python console it uses the following commands: >>> __objs__=[] >>> __objs__.append(FreeCAD.getDocument("Unnamed").getObject("Box")) >>> import ImportGui >>> ImportGui.export(__objs__,"C:/Users/bitterli/Documents/test.step") >>> del __objs__ It works if I use manually the following commands: >>> import Part >>> __objs__=[] >>> __objs__.append(FreeCAD.getDocument("Unnamed").getObject("Box")) >>> Part.export(__objs__,"C:/Users/bitterli/Documents/test.stp") >>> del __objs__ >>> | ||||
| Additional Information | OS: Windows 7 Platform: 32-bit Version: 0.14.2370 (Git) Branch: master Hash: a836759ebd91404954a778ff8885e152611576e1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 | ||||
| duplicate of | 0001210 | closed | DLL load failed |
When trying to do the export with the GUI do you get an error message? You can also enter "import ImportGui" into the Python console to see whether the module loads or not. |
there is an error message when trying to load importGUI.: import ImportGui Traceback (most recent call last): File "<input>", line 1, in <module> ImportError: DLL load failed: The specified module could not be found. |
OK, this means that the install package lacks of a certain file. We had this in the past but I don't know why this happened again. |
Here is the corresponding forum link: http://forum.freecad.org/viewtopic.php?f=3&t=4627&p=36273&hilit=importgui#p36273 /view.php?id=1210 |
Fixed with the latest installer versions for 0.14 |
| 2014-02-26 10:31 | rolbit | New Issue | |
| 2014-02-26 10:31 | rolbit | File Added: test.FCStd | |
| 2014-02-26 13:27 | wmayer | Note Added: 0004307 | |
| 2014-02-26 14:02 | rolbit | Note Added: 0004308 | |
| 2014-02-26 14:53 | wmayer | Note Added: 0004309 | |
| 2014-02-26 15:03 | wmayer | Note Added: 0004310 | |
| 2014-02-26 15:03 | wmayer | Relationship added | duplicate of 0001210 |
| 2014-03-15 13:15 | wmayer | Note Added: 0004451 | |
| 2014-03-15 13:15 | wmayer | Status | new => closed |
| 2014-03-15 13:15 | wmayer | Assigned To | => wmayer |
| 2014-03-15 13:15 | wmayer | Resolution | open => fixed |
| 2014-03-15 13:15 | wmayer | Fixed in Version | => 0.14 |
| 2014-03-15 13:15 | wmayer | Product Version | 0.13 => 0.14 |
