| 0001211 | FreeCAD | Bug | public | 2013-08-12 11:25 | 2016-05-05 20:00 |
| Reporter | axiomaticbiz | Assigned To | wmayer | ||
| Summary | 0001211: ... cannot be written to BRep file ... Error on saving a model | ||||
| Description | I have classed this as minor, not requiring fixing, because I only noticed it while running FreeCAD on Windows XP. However, I am logging it as a bug in case anybody else tries to save a complex model using an old computer with slow disc drives. The symptoms are that on re-loading the file, some (or all) the shapes fail to be rendered. In addition, if the "report window" is open, and logging of errors enabled a "... cannot be written to BRep file... messages appears on save. As workaround, each time an affected file is re-loaded, make a trivial edit to each of the affected sketches. | ||||
| Additional Information | The symptoms were found using FreeCAD version 0.13 (stable), and re-produced using Version 0.14 Revision number 2370(Git)on two Windows XP machines. They did not appear using a modern laptop. To reproduce, create a sketch containing a circle surrounded by a perimeter composed of a dozen arcs, and closed by a straight line. Pad the sketch and chamfer the resulting hole and perimeter. Create a second sketch with only a rectangle, and cut this out of the first. View the "report window", and save the model. If no error message occurs, save the model twice by pressing Ctrl+C twice in quick succession, or increase the model complexity by copying and pasting parts. This may be related to ... http://sourceforge.net/apps/mantisbt/free-cad/view.php?id=71 Since I am new to parametric modelling, I have been logging this and more tentative information on ... http://4jim.axiomatic.biz/FreeCAD/FreeCAD.html | ||||
I'll close this because it seems to me that no action is required. Please reopen if needed. |
I guess this should stay open. From time to time I got this error also on Windows but could never reproduce it reliably. I'll re-check it ones I encounter the problem... |
I haven't observed this issue for a couple of years any more. |
| 2013-08-12 11:25 | axiomaticbiz | New Issue | |
| 2014-03-11 01:55 | yorik | Note Added: 0004414 | |
| 2014-03-11 01:55 | yorik | Status | new => closed |
| 2014-03-11 01:55 | yorik | Resolution | open => no change required |
| 2014-03-11 08:40 | wmayer | Note Added: 0004420 | |
| 2014-03-11 08:40 | wmayer | Assigned To | => wmayer |
| 2014-03-11 08:40 | wmayer | Status | closed => assigned |
| 2014-03-11 08:40 | wmayer | Resolution | no change required => reopened |
| 2015-01-10 12:11 | wmayer | Note Added: 0005606 | |
| 2015-01-10 12:11 | wmayer | Status | assigned => closed |
| 2015-01-10 12:11 | wmayer | Resolution | reopened => unable to reproduce |
| 2015-10-17 13:43 | wmayer | Relationship added | has duplicate 0002245 |
| 2016-05-05 20:00 | wmayer | Relationship added | related to 0001323 |
