| 0001323 | FreeCAD | Bug | public | 2013-12-02 12:36 | 2016-05-05 20:00 |
| Reporter | NormD | Assigned To | |||
| Platform | PC | OS | Win XP Pro | OS Version | SP3 |
| Summary | 0001323: Imported .step parts disappear after save/reopen | ||||
| Description | I am building a 3D model of a PCB board. I created the basic board then created models for each part that I wanted to place on the board. I then exported each part as a .step file, imported it into the board part and placed it. So far, so good. Everything looks great. I then found that when I saved the file (as a normal .FCStd file) and reopened it, some of the parts would disappear. Which parts disappeared seems random and changes on every save/reopen. By clicking on each pad in the list of pads on the left of the display I found that the disappeared parts are still there, but are invisible. I could see this because when I double-clicked the pad a transform tool would appear where the part was supposed to be. Nothing I did to toggle visibility or appearance made the part re-appear. All of the disappeared parts were correct and visible before the save/reopen. | ||||
| Additional Information | For the file provided, please see Pads 30, 34, 35, 37 and Pocket 002, 004, 005 | ||||
I did a little more exploring. I found that a .FCStd file is a .zip file, so I unzipped it. The invisible parts all have .brp files with 0 bytes except one. Pad77 is PartShape65 which does contain data. When I checked Document.xml and GuiDocument.xml the parameters for Pad77 seemed similar to the other parameters. I just realized that the file I unzipped may be different from the one I uploaded. I assume the problem is the same. |
I did some more experimenting. If I save the file multiple times, each time different imported parts will be missing. After some number of saves, I sometimes get a complete file with no missing parts. |
I tried this using V0.14-2370 and the problem still occurs |
Are the any error messages in the report window? |
Might be related to 0001211 which is fixed. |
| 2013-12-02 12:36 | NormD | New Issue | |
| 2013-12-02 12:36 | NormD | File Added: New Board Combined.FCStd | |
| 2013-12-02 19:28 | NormD | Note Added: 0003919 | |
| 2013-12-02 19:29 | NormD | Note Edited: 0003919 | |
| 2013-12-09 17:16 | NormD | Note Added: 0003929 | |
| 2013-12-09 19:28 | NormD | Note Added: 0003930 | |
| 2014-03-04 11:40 | wmayer | Note Added: 0004380 | |
| 2014-03-04 11:40 | wmayer | Status | new => feedback |
| 2016-05-05 20:00 | wmayer | Relationship added | related to 0001211 |
| 2016-05-05 20:00 | wmayer | Note Added: 0007048 | |
| 2016-05-05 20:00 | wmayer | Status | feedback => closed |
| 2016-05-05 20:00 | wmayer | Resolution | open => fixed |
| 2016-05-05 20:00 | wmayer | Fixed in Version | => 0.16 |
